MAF problem/question
Old Apr 25, 2003 | 06:44 PM
largestal's Avatar
In a brilliant move while cleaning the throttle body, I managed to break the three solder joints in the side of the MAF that connect to the plug. Don't ask-I was being stupid.
Has anyone ever tried cutting a small portion out of their MAF housing near the plug and resoldered these connections?
The local stealership is closed and I need to (hopefully) get this put back together tonight.
Old Apr 25, 2003 | 09:15 PM
Chunger's Avatar
My other car is a Hybrid
If it's broke, why not just give it a try... nothing to lose anyways.
Good luck.
Old Apr 28, 2003 | 07:23 AM
largestal's Avatar
It took abount 30 minutes to take the cover off and get rid of all the factory sealant on top of the MAF. Fired up my trusty soldering iron and 30 minutes later, it fired right up!!
Woo-hoo! (I got lucky)
Old Apr 28, 2003 | 08:47 AM
Chunger's Avatar
Good job!
Question... while you had the cover off, did you notice if the actual hotwire was removable (screws holding it in)?
Old Apr 28, 2003 | 09:18 AM
bhmax's Avatar
I felt equally brilliant when I did this. At first, I thought I could just put it back together without soldering. However, this idea was shot down when going down the interstate and the RPMs were suddenly limited to 2500! I was on a trip and was able to slightly bend the connections to make it work right, but I eventually opened it up and resoldered. As far as the hot wire being easily replaced, I'm not sure, but I would guess not.
Old Apr 28, 2003 | 02:13 PM
largestal's Avatar
What started all of this is my being blindly stupid and removing the 4 screws that hold the connector in the side of the MAF. I pulled on the plug, thinking it would release, but I broke the three solder connections inside the body of the MAF.
A quick solder job and I am back on the road. Now I have to get some hi-temp silicone to seal it back up.
I got lucky.
TallTom
57
Oct 14, 2025 05:16 PM
-ReLLiK-
Apr 29, 2016 06:25 PM
ballerchris510
Sep 10, 2015 09:35 PM
lux97Max
Sep 4, 2015 05:42 PM
dcardello
Sep 3, 2015 11:44 PM
