Old Engine, Re-newed
Old Apr 27, 2003 | 06:52 PM
ZeRo--MaX's Avatar
My car is very old and I wanted to know what should I buy to get it up again, like spark plugs and stuff?
Old Apr 27, 2003 | 06:54 PM
ZeRo--MaX's Avatar
oil filters and stuff like that...
What kind? what brand?
Old Apr 27, 2003 | 07:50 PM
ZeRo--MaX's Avatar
bump
Old Apr 27, 2003 | 09:12 PM
KWheelzSB's Avatar
oil filter: OEM
plugs: NGK coppers or platinums
Check the maintenance tables in your Nissan manual for service items you need to take care of, based on your mileage & usage.
Old Apr 27, 2003 | 09:14 PM
imstuckherenow's Avatar
engine flush, you can buy at autozone for cheap!! tranny flush, coolant flush, throttle body cleaning..... theres lots more im sure !
Old Apr 27, 2003 | 09:29 PM
krbga's Avatar
Go to AutoZone or Pep Boys and TRY:
1. Fuel Filter...$9
2. PCV Valve.....$5
3. Redline or Chevron(Techron)Fuel injector Cleaner...$5
4. Throttle Plate/Itake Cleaner...$4
5. NGK Platinum Plugs...OEM(PFR5G-11)...Dealer$70 or Ebay Store$40
6. Coolant Flush add Redline Water Wetter $5
7. Auto Tranny Flush or if high miles...Drain/Fill $40-$90
8. Oil Change...Synthetic/Non...the debate goes on...but just make sure you get the oil Temperature HOT at the DRAIN time... to get a FULL drain of the old oil.$24-$50
9. Tighten the Throttle cable (Free)
10. Clean off your Battery Posts (Free)
Old Apr 28, 2003 | 08:12 PM
ZeRo--MaX's Avatar
do someone know a write up about cleaning your trottle body, tighten trottle cable and all that stuff??
Old Apr 28, 2003 | 08:16 PM
-MaxPayne-'s Avatar
www.motorvate.ca has instructions on how to clean the tb, as well as many other usual how 2's...
-payne
carnal_c30's Avatar
Former Sponsor
look at the 4th gen FAQs i believe it covers all of this and there are links to write ups there
Old Apr 28, 2003 | 08:50 PM
ZeRo--MaX's Avatar
I found out how to clean the tb but not how to tighten the cable?
Old Apr 29, 2003 | 11:16 PM
A5295's Avatar
sweet-i was just gonna ask about this when my car is back in the road...
James92SE
142
Jan 2, 2024 09:23 AM
homewrecker
Sep 24, 2015 07:01 PM
msellas
Sep 23, 2015 09:16 PM
Socalstillen
Sep 20, 2015 11:46 PM
seesole
Sep 14, 2015 12:38 PM
