2000 Max Engine fitting issues
Old Apr 28, 2003 | 09:39 AM
98maxsel's Avatar
Can you fit a VQ30 from a 2000 in a 97-99 maxima? This questions prolly been asked before but without the search I have to ask again.
Thanks.
Old Apr 28, 2003 | 09:40 AM
95maxmadman's Avatar
As I've been told, yes.
I'm thinking about it myself.
Old Apr 28, 2003 | 09:42 AM
mzmtg's Avatar
Minister of Silly Walks
Anything can be done with enough time and money.
I don't know why you would want to do this. There are MUCH easier ways to get 222hp out of your existing VQ30DE.
Old Apr 28, 2003 | 09:45 AM
Bluebird's Avatar
I am Roid Rage
I'm pretty interested in this myself. Specifically because I have a 99.5 and I'm told that the 2000+ ECU fits the harness for the 99.5 ECU, thus saving me lots of headaches.
I figure that if a VI package is going to cost me $650, why not just drop the DE-K in?
Old Apr 30, 2003 | 05:45 PM
98maxsel's Avatar
cause I saw a VQ30DE-K on ebay for $800 with 20,000 miles on it!
Old May 28, 2003 | 11:20 PM
maxima_se007's Avatar
I would be interested if I could fit a VQ35DE in my 4th gen. I would only resort to this if my VQ someday gave out. (prolly not soon)could it be done?
Old May 29, 2003 | 01:42 AM
ch13f's Avatar
Well, labor charges (or time if you do it yourself) make it alebit (read: a lot) more expensive than just adding a VI. If you happen to blow your current engine and needed to swap in a new one, then I would say go for it.
Old May 29, 2003 | 05:50 AM
njmaxseltd's Avatar
I'll just copy this again, maybe they'll get it this time around.
Intake + Y pipe on a 4th gen = about 222 HP
Total cost is under 250 bucks.
Old May 29, 2003 | 06:28 AM
Bluebird's Avatar
I am Roid Rage
C'mon Tom. You, as a 99.5 owner should realize the potential of this. Yes I could add a intake and Y-pipe, which I have, but why not keep going? Withe the DE-K + an intake and Y-pipe you might be looking at 240 flywheel hp? Why would you just write this off?
Old May 29, 2003 | 06:40 AM
njmaxseltd's Avatar
Good point!
But I think I'd be looking at an SC over just dumping another engine in.
I guess I like to keep the car with the parts it came with and just add onto it to improve it's performance.
If I wanted to start with a 222HP engine, I'd trade my 4th gen in for a 5th gen and then start modding from there.
Old May 29, 2003 | 07:04 AM
deezo's Avatar
Good point!
But then you would have to have to think about owning an ugly car.
Old May 29, 2003 | 07:10 AM
Nealoc187's Avatar
SLOW
Ultimately (with bolt ons) both engines end up having just about the same HP to the wheels anyways do they not? 2000-2001s (the one's that AREN'T BROKEN AND ONLY PUTTING DOWN LIKE 180FWHP WITH I/Y/E) are putting down just over 200fwhp... like 205ish max right? Full bolt on 95-99s are putting down 195ish... All that R&D and labor is alot of money to spend for 10 extra hp in the long run... I think anyone considering this is a little out of their mind (not in a bad way though, just seems like tons of work for little reward, but R&D like this is what it takes to innovate)... IF you are going to swap in a motor swap in a 3.5... it will probably take the same amount of work (I have a very difficult time believing that 2000-2001 ECUs and 99.5 ECUs are interchangable. The harness may be the same but I doubt the ECUs are).
Wow I used tons of parantheses and ellipsis in this post please forgive me I hate it when I do that but I'm not retyping that whole thing.
Old May 29, 2003 | 07:20 AM
njmaxseltd's Avatar
Old May 29, 2003 | 07:31 AM
Bluebird's Avatar
I am Roid Rage
Good points Neal. But you have to figure that us 99 and 99.5 guys are pretty much screwed when it comes to in-depth NA modding. Yes, we can get the VI. But we can't get the ECU and bumped up rev-limiter that is available to the others.
CRizz
41
Jun 7, 2021 05:42 AM
maxocar
Aug 21, 2015 12:57 AM
twotonezed
Aug 16, 2015 11:41 AM
jholley
Aug 11, 2015 09:38 AM
