here is the "correct" way to install a Harlen switch.
Old Apr 30, 2003 | 08:28 PM
plurco's Avatar
in my opinion anyway.
http://www.cardomain.com/member_page...=287228&page=5
Old May 1, 2003 | 12:22 AM
Iron Lung's Avatar
Nice install. I like the idea of twisting the wires
Old May 1, 2003 | 12:44 AM
ballinontwins's Avatar
Excuse me for not knowing what a Harlen switch is. Can you explain what it does, and what its for?
Old May 1, 2003 | 03:25 AM
pruizgarcia's Avatar
Re: here is the "correct" way to install a Harlen switch.
I also have no clue what it is or what it does...
Pedro
Old May 1, 2003 | 04:48 AM
redmaxpa007's Avatar
i SeE what you did therE
your install was well thought out..
Old May 1, 2003 | 04:57 AM
Ninos_Maxima's Avatar
be the change u want2C
Re: Re: here is the "correct" way to install a Harlen switch.
Pedro
I yay that movememt!
Old May 1, 2003 | 05:27 AM
Confused's Avatar
Permanent Maxima.org Resident
The harlan switch is an rpm switch made by a guy named Harlan. In this case its used to open the variable intake at a specified rpm.
http://www.harlan-engineering.com/
btw, nice install.
Old May 1, 2003 | 08:21 AM
XXXL Cracker's Avatar
Nice and clean.... amost as nice as mine
D
Old May 1, 2003 | 09:13 AM
venompwr2's Avatar
I just have mine strapped to the cables coming off the battery w/ zip ties...
The switch sets the rpm's that you want the mod you have hooked up to it to operate at. In my case it's the nitrous, it'll spray from 3200-6000 with the window its currently at- hence the name "window switch"
Old May 1, 2003 | 11:33 AM
hlh0501's Avatar
clean install, well done.
one note, i saw on your site you are going to cryo treat just 2nd gear.. if you are going to pull the gears, have them all done, it is barely any more money, and you want 1st treated if you plan to drag on slicks, and 3rd often blows so its worth having done too. just a suggestion
MaxLife17
Jun 27, 2019 01:37 PM
mikeg75
Nov 30, 2015 05:12 PM
James92SE
Oct 8, 2015 04:57 PM
2kmaximel
Sep 16, 2015 03:19 PM
Maxie40
Sep 14, 2015 11:28 AM
