Hanabi HIDs fade
Old May 2, 2003 | 08:38 AM
Stillen_I30's Avatar
Hanabi HIDs fade
I just installed the 8,000K kit yesterday. I noticed that when i first flick on the HIDs, they are nice and bright, but after about 10 seconds, they fade down considerably. Then, once again, they fade down again (its not a gradual fade, its a sudden fade where it looks as if it shifts down to a lower brightness all of a sudden). Then i notice that the lights somewhat flicker for a few seconds, and then it seems ok. Whats with the fading though?? I wish it hadnt done that.
Old May 2, 2003 | 08:48 AM
njmaxseltd's Avatar
Check your connections. Make sure they are nice and solid. Don't use those quick wire tap things. They will eventually come lose again.
Old May 2, 2003 | 08:56 AM
ny96max's Avatar
sounds like you have a bad kit and a bad not connection. I would exchange them ASAP.
Ant
Old May 2, 2003 | 09:54 AM
99Maxima5sp's Avatar
i like the trunk mod ant...My friend did that to his hooked up 91 Accord Coupe before he sold it...Never before seen it on a max...
And stillen I30, just return them if you can, that doesnt sound too good.
Eric
Old May 2, 2003 | 11:21 AM
Mad Dhan's Avatar
what he said, check ur connections, i doubt its serious
Old May 2, 2003 | 11:30 AM
araffio's Avatar
I had a connection problem when I first installed my Hanabi's. One of the plugs had a little in and out play, causing the bulb to go out randomly, so I used a zip tie around it to hold it tight. Haven't had a problem since.
The lights should be kinda dim when you turn them on, then gradually get brighter and brighter...I know that's what mine and Ant's do. Right Ant?
Old May 2, 2003 | 12:23 PM
GoldenGlory
must be a bad connection. i got the 7k kit and crap i light up about anything on or near thats in front of me.
Old May 2, 2003 | 12:36 PM
djshawnee's Avatar
to some extent that is normal, the bulb has to warm up, so the bulb gets to its correct color and brightness.... when i turn mine on they change colors a bit and flicker a little... thats just them warming up. i wouldn't worry too much about it.. mine have always done it, and i have no problem with them so far
Old May 2, 2003 | 12:38 PM
GoldenGlory
Old May 2, 2003 | 01:43 PM
thanks for the suggestions. i just posted another thread about the kit...the lights dont work now! all i did was relocate one of the ballasts, and that light went out. then, i jiggled wires, checked connections, etc, and then the other one went out. just to clarify: the lights fade a few seconds after I turn them on. I have seen a countless number of vehicles with HIDs, and none dim down suddenly like mine do. its almost like as if there was a brightness switch that was being turned down from "HI" to "LOW" not a gradual dimming. here is the story:
https://maxima.org/forums/showthread...hreadid=212008
called up freddie, but i think he's busy right now.
Old May 2, 2003 | 01:50 PM
GoldenGlory
I M now - nvthispapii
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
Mochedda
Dec 15, 2015 11:27 AM
Vistance
Sep 17, 2015 05:17 AM
