weapon r coil overs
weapon r coil overs
hello guys, ok major problems!!!! I bough the weapon r coil overs form a fellow org member. Then i am not sure if he did not send it, or lost it in the mail, or i lost it. I lost one of the rear alignment caps. Then i called weapon r they sent me the cap with the little **** on top, they said it would fit the back fine. i had maximumtunning install it, and now they r makign a tap tap noise in the back, everytime i hit a bump, need advice, and where can i get new rear alighment caps, with the little holes. also This setup is very bouncy, or is it jus mine cause of the rear problem. scared very scared, help me please and what should i set the kyb strust to 2 and 4 ish it good,
idot question
as the numbers go up, it gets harder or softer, i am confused
idot question
