Busted console trim piece
Old 05-06-2003, 09:30 PM
TooMAX's Avatar
There's a plastic trim panel in the center console that goes around the gear shift, holding the shift boot and the cig lighter in place. Well, it's broken around the lighter due a lot of cell phone charger use. Anyone know what the part number of this piece is or what it's officially called? Does a manual have the same trim piece as an auto? Maybe I'm better off hunting for it in a junkyard? I'll be installing new shift and e-brake boots soon and want to take care of it at the same time. - thanks
TooMAX is offline
Old 05-06-2003, 10:20 PM
Ramius83
That is your shifter trim piece. You can find them on eBay, your local dealers, and other maxima.org members, such as Max4Speed. BTW, is your car an auto or 5-speed...
Old 05-07-2003, 12:21 AM
Nismo's Avatar
5sp and auto are different and its like $70 for a new one at the dealer.
Nismo is offline
Old 05-07-2003, 10:10 AM
TooMAX's Avatar
$70 - ouch! I have a 5 speed.
Anyone have a P/N that I can use to search on-line?
TooMAX is offline
Old 05-07-2003, 07:08 PM
s0ber's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2414198735
s0ber is offline
Old 05-08-2003, 12:10 AM
TooMAX's Avatar
Thanks for the link and your effort, sOber. Although I don't need the whole console, it looks to me that it's for an auto but I'll email the seller to be sure. I think I'll be haunting a few of the local yards this weekend to see what I find too.
TooMAX is offline
Old 05-08-2003, 02:26 AM
Bgohan's Avatar
Re: Busted console trim piece
If it is a fairly clean break, and the peices fit back together tight, you can use a plastic weld glue, and touch up the joint with a permanent ink felt pen if needed. Get the plastic weld glue at auto parts store. It's a 2 part glue. It works when used properly. the key is to clean, clean, then clean again and then ad primer properly. After gluing, wait a day before reassembling.
Also, some auto plasics made of PVC can be repaired with sprinkler pipe primer and glue. If possible, glue a piece of scrpa plastic on back side of brake to stenthen repair joint. I've made several of these repairs, and I could barely see it was ever broken, and only because I knew it was.
Bgohan is offline
Old 05-11-2003, 10:47 PM
TooMAX's Avatar
Re: Re: Busted console trim piece
Hey - great idea! (superglue doesn't work so well)
So I did some 'welding' tonight and the piece isn't so bad now. I beefed up the support on the backside with extra epoxy and I think it might be strong enough to hold the 12V outlet. At least it's functional, and I'll see how much I notice it when it's back together. Thanks again.
TooMAX is offline
Old 05-13-2003, 10:39 AM
Ravq's Avatar
You could always hit the junkyard too.
Ravq is offline
REDinLV
08-15-2024 12:30 AM
gigabyte
01-06-2017 06:05 PM
BobTX10
10-07-2015 08:43 AM
JakeOfAllTrades
09-30-2015 03:16 PM
Redfox
09-28-2015 10:41 AM
Quick Reply: Busted console trim piece
