New headlights = no lights?
Old May 8, 2003 | 02:46 PM
MaximusMax's Avatar
I just installed a new pair of sylvaina (sp?) bulbs for my headlights. They look great, but now I have no clearance lights (they only turn on when I signal, and they are very dim), no side marker lights (lights next to the turn signal), and my rear lights are not turning on (only when I press the brake pedal do they turn on). Could I have blown a fuse just by changing my headlights, and how could it turn all the other lights off? Advice would be greatly appreciated!
Old May 8, 2003 | 02:55 PM
GrkMchn's Avatar
fuse?
Old May 9, 2003 | 06:39 AM
Dasyce's Avatar
sounds like a fuse.. check to see if your brake lights come on anymore.. cause its the same fuse
Old May 9, 2003 | 07:17 AM
cam_honestiam's Avatar
It is (probably) the "Tail light" fuse, a 7.5 amp fuse to the middle/left of the fuse box under the steering wheel. You may have a ground wire touching the body of the car or something. If you have done any of the corner light mods, or headlight mods, you may want to re-check your wiring job.
Old May 9, 2003 | 07:19 AM
It is (probably) the "Tail light" fuse, a 7.5 amp fuse to the middle/left of the fuse box under the steering wheel. However, you say that your corners come on dimly...the corners are on the same fuse as the tail lights, unless you rewired something...You may have a ground wire touching the body of the car or something. If you have done any of the corner light mods, or headlight mods, you may want to re-check your wiring job. The brake lights are actually on a separate fuse (at least, on my '98 SE they are) as the tail lights.
mvm062
Nov 30, 2020 09:00 AM
MaxLife17
Jun 27, 2019 01:37 PM
MaxLife17
Sep 8, 2015 02:36 PM
Maxima30
Sep 7, 2015 06:13 PM
sdotcarter
Sep 2, 2015 09:53 PM
