Want to remove air intake snorkal but not sure about how
Old May 10, 2003 | 02:34 PM
bb0ys's Avatar
I've got a midpipe and jwt popcharger and I want to remove the original lower intake air box. I'd also like to remove the snorkal and tube that leads to the lower box. I noticed there is a plug that goes into the snorkal pipe right before it enters the lower box. What should I do with this? Also, there is a Boost Control element at the upper part of the snorkal where air enters. Any suggestions on where to remount this. It is currently on a metal bracket that is screwed into the snorkal.
The car is a 97 SE manual transmission.
Thanks!
Old May 10, 2003 | 02:54 PM
xHypex's Avatar
The boost control solenoid can just get zip tied to wires of your choice. Removing the snorkel is really easy, and basically just pops off. The plug that you see is the ambient air temp sensor and goes in the hole in your mid pipe.
-hype
Old May 10, 2003 | 07:40 PM
bb0ys's Avatar
No hole in pipe
I don't have an extra hole in the mid-pipe. I've got 3 "ports" on it. A tiny one facing the firewall, a large one facing the firewall, and one facing the front of the car. All three have hoses in them (hoses go to the same place as the 3 hoses that were running off of the stock resonator box). I'm not sure where I should put the ambient air temp sensor?
Old May 10, 2003 | 09:10 PM
xHypex's Avatar
You should have room for 3 hoses: 2 large (1 on each side of the pipe), and 1 small vacuum hose on the firewall side. You should also have a hole for the ambient air sensor, but if you don't just zip tie it somewhere. It's not crucial, but it is good to have in the right place. What brand midpipe do you have? As far as I know only the PR midpipes have the hole precut
http://photos.imageevent.com/xhypex/...e/IMG_3227.JPG
http://photos.imageevent.com/xhypex/...e/IMG_3230.JPG
Ignore the brass fitting in the intake
-hype
Smackasmith
Feb 1, 2016 12:40 AM
trailer54
Nitrous
Nov 18, 2015 07:44 PM
Maxboy23
Sep 9, 2015 10:37 AM
Maxboy23
Sep 4, 2015 06:04 PM
lux97Max
Sep 4, 2015 05:42 PM
