To all those with hesitation problems
Old May 12, 2003 | 03:54 PM
  #41
Nismo's Avatar
got done with mine. I soldered a wire to the maf by splicing the insulation then soldered it. I grounded it on a terminal ring on the same place where I have my airhorns grounded to which is to the upper strut where the auto drop resistor is located. I dont think I felt anything which is what I was expecting since I dont believe I have any problems to begin with
Old May 12, 2003 | 03:56 PM
  #42
97MaximaSE's Avatar
if i can get use of a digital camera tomorrow night i will take a pic for everyone....6 days now and still no hesitation so im happy
Old May 12, 2003 | 04:14 PM
  #43
TooMAX's Avatar
Originally posted by mzmtg
That's twice you needed it
Old May 12, 2003 | 04:20 PM
  #44
mzmtg's Avatar
Minister of Silly Walks
I did it. It works
NO PICS !
Old May 12, 2003 | 04:50 PM
  #45
maxspeed96CT's Avatar
The original VQ...
Originally posted by D1NOnly34
Did mine as well, felt ok when i test drove it. When I got into my driveway, felt like checking the ECU, got the knock sensor code, doh! I dont know if it was from before or just happened. I resetted it and we;ll see what happens.
didn't do it yet cause it starte rinin and i got lazy.
thanks for postin about this, im gona check for codes before i do this .
Old May 12, 2003 | 05:09 PM
  #46
ZuMBLe's Avatar
I just drove around with it. Umm, I won't say if it works or not. My butt dyno may need to be recalibrated. But I'm leaning towards it working.
Old May 12, 2003 | 05:18 PM
  #47
njmaxseltd's Avatar
I'm making chicken wings for dinner.
Old May 12, 2003 | 05:21 PM
  #48
D1NOnly34's Avatar
Old May 12, 2003 | 06:23 PM
  #49
96shogunmax's Avatar
Mine feels ohk...
Old May 12, 2003 | 08:46 PM
  #50
97MaximaSE's Avatar
i dont have a check engine light and i dont see why this would set off the knock sensor code....all i know is my car runs and feels better than it has in years
Old May 12, 2003 | 08:55 PM
  #51
D1NOnly34's Avatar
I didnt have a light, I just checked for the heck of it. Knock sensors dont trip the ECU, unless theres another code with it.
Old May 12, 2003 | 08:56 PM
  #52
97MaximaSE's Avatar
i know ive already replaced mine but it i checked the ecu after i did the wire and its not on so you must have had this problem coming. mine went around 70k miles
Old May 12, 2003 | 09:01 PM
  #53
D1NOnly34's Avatar
Well I checked the other day my ECU (maybe liek 2 days or so) and all I had was the rear heated o2 sensor, but I reset that and it hasnt come back. Ill check it out tomorrow. I also replaced my Knock Sensor =/ Maybe the wire is loose or not on correctly, cause I still get jerking at idling (sluggish, loss of power and horrible gas mileage) or maybe injectors, who knows. =(
Old May 13, 2003 | 07:22 AM
  #54
Dave B's Avatar
Not DAVEB the parts guy
You guys really should have checked your MAFs with a voltmeter to confirm if your MAF had a grounding problem. Mine apparently did and after driving for nearly three days, I'm happy to report my car lacks the slight hestitation it use to have from 2000-3000rpms. Overall the car just drives better. Faster? That's hard to gauge because even if this thing added 5hp, you wouldn't really feel it. Btw, I don't think it adds much if any power. This is a driveability mod.
Dave
Old May 13, 2003 | 07:48 AM
  #55
Miasma's Avatar
lets think about this:
there are two reasons that your MAFs resistance is too high -- your maf is aging, but that doesnt make the ground bad. Or, your grounding system in the car is inadequate. This fix seems like a bandaid fix, but chances are that the MAF grounds to the same point as many other things. Dont you guys think we would be better suited to find the ground point and clean up the metal contact or put in larger wires? Making another ground point is not always a good thing, ground loops can cause lots of interference for example. Does anyone know where the stock MAF ground is?
Old May 13, 2003 | 08:59 PM
  #56
97MaximaSE's Avatar
i have a pic but i have no place to upload it to
Old May 13, 2003 | 09:14 PM
  #57
if you turned your aim on i could upload it for you...
Old May 13, 2003 | 10:27 PM
  #58
TooMAX's Avatar
Dave
You're right, this won't add any power, but will hopefully restore what could be lost if the MAF ground reference voltage has increased over time. The throttle response just feels a bit smoother when it's right. In the SR20DE, it gave a more rev-happy feeling.
Miasma - The black ground wire returns direct to the ECU, giving a ground reference in relation to the white MAF signal wire. There is no MAF ground point other than through the ECU according to my Haynes diagrams. This mod ties the MAF (and ECU) electronic ground directly to chassis ground, which really should be the same to avoid ground loops. If the MAF ground wire isn't at true ground, then the ECU will read the MAF signal a little too low. The OEM signal wires are about 22 gauge, which does have cumulative resistance over the 10 feet or so that grounds the MAF back to the ECU. This mod grounds the MAF with a short, larger cable. The ECU does have grounding wires in its ribbon cable, but I don't know where they attach - probably under the dash somewhere.
Old May 13, 2003 | 10:36 PM
  #59
Miasma's Avatar
Miasma - The black ground wire returns direct to the ECU, giving a ground reference in relation to the white MAF signal wire. There is no MAF ground point other than through the ECU according to my Haynes diagrams. This mod ties the MAF (and ECU) electronic ground directly to chassis ground, which really should be the same to avoid ground loops. If the MAF ground wire isn't at true ground, then the ECU will read the MAF signal a little too high. The OEM signal wires are about 22 gauge, which does have cumulative resistance over the 10 feet or so that grounds the MAF back to the ECU. This mod grounds the MAF with a short, larger cable. The ECU does have grounding wires in its ribbon cable, but I don't know where they attach - probably under the dash somewhere.
interesting stuff.
this mod couldnt hurt anything, I am just wondering if providing the entire ECU a better ground would help at all... also all sensors can benifit from a more stable ground... could be an interesting project, like ooglie-hypergrounds to the nth power!
Old May 13, 2003 | 10:48 PM
  #60
BigJayx23's Avatar
wat size gauge wire did everyone use to make this extra ground wire for the maf?
  #61
4 gauge...........
j/k 16 gauge
Old May 13, 2003 | 10:51 PM
  #62
Miasma's Avatar
screw wimpy 4awg, try 4/0awg!
Old May 13, 2003 | 10:55 PM
  #63
BigJayx23's Avatar
hahahhha
Old May 15, 2003 | 07:10 AM
  #64
goldmax's Avatar
Re: To all those with hesitation problems
Good post! FYI...I checked the shop manual last night and it has a very detailed section on how to check all the MAF lead voltages.
One part of the writeup recommends removing and cleaning the wiring harness ground that are located in the front middle of the top of the engine near the injectors. There are two grounds within about an inch of each other.
The manual also mentions being able to test the ground lead by checking voltage between pin 55 (MAF ground lead you mention) and pin 25 (computer ground). The recommended mv reading is "0".
I cleaned up the harness grounding leads last night and the idle and low end has improved greatly! Will check the pin voltages tonight to see if I need to do your mod!
Old May 16, 2003 | 02:42 PM
  #65
97MaximaSE's Avatar
this is what i did
http://jamsan.homestead.com/files/maf.jpg
ahh screw it i suck at html here is the link
Old May 16, 2003 | 02:46 PM
  #66
Jamsan's Avatar
yes, you do suck
Old May 16, 2003 | 02:58 PM
  #67
97MaximaSE's Avatar
Originally posted by Jamsan
yes, you do suck
im telling you it wasnt working for me
Old May 16, 2003 | 05:21 PM
  #68
D1NOnly34's Avatar
I can't really tell, but did you ADD a ground wire, or did you just cut the wire and re-ground it to another location?
Old May 16, 2003 | 08:47 PM
  #69
Dave B's Avatar
It's been 4 solid days of driving and I'm happy to report ALL my car's "hiccups" and bumpiness in the powerband during part throttle acceleration are all gone. I'm very happy with the improved driveability.
Dave
Old May 16, 2003 | 09:04 PM
  #70
Miasma's Avatar
i will try this tomorrow, but it really makes me think that the MAF is not all that can benifit from better grounding.
Old May 17, 2003 | 05:25 AM
  #71
97MaximaSE's Avatar
if you look you can tell i just spliced into the current ground wire and added another one
Old May 17, 2003 | 11:29 AM
  #72
dave harms's Avatar
Grounding
-Grounding is always the most important electrical contact.
-But in the case of the MAF, it is critical, because the sensor is a variable resistor, and a slightly corroded ground will have major impact because the ECU will interperate the bad ground (change in resistance) as a specific signal. Other grounds are often used as 'on/off' signal point, therefore having a functioning or fully non-functioning (sometimes intermitent, caused by bumbs, etc.) symptom.
-I think when the weather warms (monday), I'll be testing mine, just as a precaution.
Old May 17, 2003 | 11:47 AM
  #73
BigJayx23's Avatar
so basically all it is... u just splice into the existing ground wire to the maf sensor...adding another ground wire... while still keeping the original ground wire intact... which makes 2 ground wires for the maf.... correct?
Old May 17, 2003 | 12:09 PM
  #74
95seMax's Avatar
how bout if you just clean the spot where the ground wire for the maf is connected to
will it still have the same effect, should get better charge if you just clear the area of the original ground wire instead of making two , one with a better ground and the original one?
Old May 17, 2003 | 01:04 PM
  #75
TooMAX's Avatar
YUP
Old May 17, 2003 | 01:14 PM
  #76
funmax's Avatar
It works like a charm.
This is the best mod ever.
Old Nov 6, 2003 | 08:12 AM
  #77
Dave B's Avatar
I thought I'd bring this post back from the dead. Last night while looking under my hood, I noticed some exposed bare wires underneath some of the electrical tape I used to cover the wire tap of the extra grounding to the MAF. I pulled the tape off and to my surprise, the soldered extra ground wire fell off and my main MAF ground only had about 50% of the wire strands still connected. I removed the extra ground and fixed the main ground wire.
So pretty much while trying to make my MAF have a better ground, I actually made things far worse
Dave
user 11122324
42
Jul 18, 2022 03:35 PM
Unclejunebug
Apr 2, 2016 05:42 AM
Noela
Sep 26, 2015 08:22 AM
homewrecker
Sep 24, 2015 07:01 PM
