4 months in my garage & now trouble starting my max
Old May 11, 2003 | 08:42 PM
delacruz_17's Avatar
well my poor max has been sitting in my garage since like Januaray. Reason:lots of tickets, and water pump broke. I haven't had much time to work on it. So in the end i took off the timing chain cover (don't ask why, i just did) and replaced the water pump and i know for sure the chain is on correctly too. Well i have put back the cover and tryied to start her up but no hope. Just a bunch of noise. I can get it on every once in a while but i have to jiggle the key around to make it start. If I don't jiggle the key then it won't start.
I haven't connect everything like the crankshaft pulley, belts, ac compressor, and the alternator is connected but is lying on the floor.
I don't know what the problem could be. I tested if a spark was coming out of the spark plug cable and "nada", nothing. Can someone give some advice anyhing would do.
Old May 11, 2003 | 09:57 PM
KWheelzSB's Avatar
Re: 4 months in my garage & now trouble starting my max
Check the condition of your battery using a hydrometer (available at any auto parts store for under $5). If you haven't maintained the battery during the car's storage time, it may have discharged enough to cause the problems you're experiencing.
If however, you're convinced the ignition switch is playing a role, that's another matter. Start with a battery checkup.
PS: Generally speaking, it's a bad idea to start & run an engine without the alternator hooked up & providing power to the electrical system. Why the need to run it disassembled? Put it all back together first.
Old May 11, 2003 | 10:14 PM
yea its just that im really lazy to put it back together and then find out later that i will have to take apart everything again. I work on the car for like 6 hours and i just wanted to see if it started up. Im going to try with everything connected tomorrow. I'll keep postin'
02PearlSE
Oct 7, 2015 02:12 AM
homeyclaus
Sep 3, 2015 06:15 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
scarletsosa
Aug 17, 2015 09:09 PM
Balkins
Aug 12, 2015 06:39 AM
