Changing belts?
Changing belts?
Is there a website that shows how to change the belts in our car...they're starting to squeel and they need to be changed. I know that one of them, you have to take off your passanger side tire, but I can't remember what else. Thanks
Are you sure its your belts and not your starter? I thought my belts were squeeling. It would only do it momentarily on cold starts. But I have new belts, so i tried re-tensioning the belts and it didnt work. Im pretty sure its my starter. I tried to remove the starter and repack the grease on the one-way clutch. I couldnt get the 17mm bolt off. Im going to try again with some bigger tools (+100 ft.lbs)
and that 17mm bolt, you might need 140+ ft.lbs to losen it. I used my torque wrench to losen it. I had to go over the limit of my torque wrench which was 140 ft.lbs
RWCreative
Sep 21, 2015 11:01 AM
