ECU Removal
Old May 14, 2003 | 03:06 PM
97MaximaSE's Avatar
ECU Removal
How do you do this....anyone have any step by step directions?
Old May 14, 2003 | 05:34 PM
Keven97SE
It's actually very simple. Loosen the bolt holding on the wiring harness connector and disconnect the harness, then remove the 4 screws holding the ECU to the bracket and remove the ECU.
...unfortunately, the 4 screws are ridiculously difficult to remove. A standard shorty phillips head screwdriver is way to long to remove. You need to use one of the ratchet-style screwdrivers, and even with one of those it's a pain.
Old May 14, 2003 | 07:31 PM
Nismo's Avatar
only screw that was a bish was the passanger side one in the rear. the rest were pretty simple using a small 90 degree angle ratched screwdriver. after you take it out you can just leave out that hard screw since it holds fine with only 2-3 screws
Old May 14, 2003 | 09:45 PM
97MaximaSE's Avatar
lol i took my whole dash apart today before just giving up on it....i will have to go buy some tools tomorrow then..thanks
Old May 14, 2003 | 10:15 PM
I30tMikeD's Avatar
Yeah, I am not looking forward to doing this. I have to send my ECU into JWT this week. Nealoc187 said it was one of the most PITA things he has had to do to his car.
He suggested the same thing. Disconnect the mounting bracket from the car and take the whole thing out. He also said taking the dash apart may be the best way.
Old May 14, 2003 | 10:27 PM
Iilac's Avatar
Spelled with a I not a L for Iilac. Prounced Ii-eee-ack.
Get a offset ratcheting screwdriver. The one I got was from craftsman and the product code is 4116. You don't have to take the whole dash off, just have a good friend do it for you....
Old May 14, 2003 | 10:31 PM
Nismo's Avatar
lol, actually I can probably swap one ou tin like 5 min now
Old May 15, 2003 | 09:45 AM
97MaximaSE's Avatar
well i just got my geforce in and i like it....i was gonna get the jwt but i had no need for a raised rev since im auto and i got a good price on the geforce
Old May 15, 2003 | 10:03 AM
Requin6's Avatar
ditto, BIG TIME PITA. i dislodged all the annoying nissan clips that hold the thick harness to the bracket and removed the whole thing with the bracket. this was after i got all 3 screws out no problem but the drivers side firewall one got me. it stripped in a heartbeat. i put the JWT in with the 2 front screws only (dashboard side) and it holds no problem.
--Paul
my03maxima
Jul 28, 2024 07:40 AM
gigabyte
Jan 6, 2017 06:05 PM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
