fstb installation
Old May 14, 2003 | 08:40 PM
RapidMax's Avatar
fstb installation
I just got my front strut bar but maximadriver.com is down so I can't get the write up on how to install it. I pretty much know what to do but want to make sure I don't forget anything. Also, is it possible to do with a normal wrench and not a torque wrench?
Old May 14, 2003 | 09:04 PM
Nismo's Avatar
take off all 6 nuts, put bar on, hand tighten nuts, expand bar so theres no play, retorque nuts to 34 ft lbs or if you dont have a torque wrench just make shure there all equally tight.
Old May 14, 2003 | 09:10 PM
aznsap's Avatar
i have a cheap $15 torque wrench. are there good quality torque wrenches that i should use? i want to install a udp later, so i would need to be accurate on torquing bolts.
Old May 14, 2003 | 09:16 PM
Nismo's Avatar
any torque wrench will do on a fstb. its not that important like torquing wheels so you will be fine as long as its within reason. BUT, I would suggest a quality click type one like a craftsman or something if you plan to use it more than just a fstb.
Old May 14, 2003 | 09:25 PM
clee130's Avatar
Go buy a torque wrench. I got a decent "click-type" for just $20 and it has come in handy more times than just for installing the FSTB.
If you don't feel like springing for a measly $20, you could always go to an auto parts store and if they have a rent-a-tool program, you could borrow the torque wrench and install the FSTB.
Old May 14, 2003 | 10:12 PM
RapidMax's Avatar
Thanks. I think I'm going to borrow one from my friend cause I want to make sure it dones right. Anyone know off hand how big the nuts are?
Old May 15, 2003 | 12:02 AM
Nismo's Avatar
14mm
Old May 15, 2003 | 01:54 AM
Bgohan's Avatar
Exact torque not that imporants on the bar. They are big bolts, and you can't break them without a cheeter bar. Just get them all good and tight, and tighten nuts evenly in a criss-cross pattern.
A $15 torque wrench is not as accurate as my forearm.
I have a 1/2" Snap-On, and it was off by 15 pounds last time I had it calibrated. It cost $75 to repair and calibrate it. Good thing I didn't have to pay for it
For an fairly accurate, but inexpensive torque wrench, get an old-fashioned one with a needle gauge, not a click-off model. The calibration of a needle model is not subject to failure and weakening of internal springs and lubrication variables. Just be sure to buy a name brand, not a swap meet model.
Old May 15, 2003 | 03:19 AM
Max Noob's Avatar
jsut done put it on backwards...the bar should not touch the brake fluid resovior. its goes behind it closer to your steering wheel..
Old May 15, 2003 | 05:26 AM
white95max's Avatar
Is an alignment neccesary after installing a FSTB?
Old May 15, 2003 | 05:28 AM
mzmtg's Avatar
Minister of Silly Walks
No.
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
