Y-pipe installed
Old May 16, 2003 | 07:57 PM
96SE5Spd's Avatar
Y-pipe installed
I finally got the budget y-pipe in the mail. I installed it today and now my car sounds a bit like it has a GM 3.8 in it. But the car feels a little faster. Other than the fact that the car sounds like a$$ with the muffler i have on it, I like the product. I had some problems with the installation because of lack of equipment, but that was handled by a quick trip to the local muffler shop (I had to get them to loosen the one bolt I couldn't budge) at no cost to me, thank God. And the hanger that supports the y-pipe and cat would not fit back on so I'm going to have to get someone to fabricate something to put in its place.
Old May 16, 2003 | 08:04 PM
99Maxima5sp's Avatar
enjoy, do you get an annoying sound at all from it?!? I get a rattling/metallic sound that annoys me but ive learned to give 2 flying f**Ks about anymore...
And yes, ive checked the flex, and tightened all bolts, and used plenty of sealer...
Eric
Old May 16, 2003 | 08:13 PM
96SE5Spd's Avatar
Eric
I get a slight rattling but I also get this freakin chirping sound when I blip the throttle, I'm going to put a 2k muffler on it and hope that it will fix the sound it makes.
Old May 16, 2003 | 10:29 PM
WOODYMAX98's Avatar
How did you get the bolts off you cat? I CAN'T get them off. And I dont know how to torch em.
Old May 16, 2003 | 10:32 PM
maximamoose's Avatar
Eric
Check about 1/2 way back on the car. There is a bracket going across the exhaust. If the pipe is even close to that, take the bracket off and put some spacers between the bracket and the pipe. I did this on tuesday???, and it made a world of difference!!!
Old May 17, 2003 | 04:41 AM
96SE5Spd's Avatar
I could only get one of them off the other I got a muffler shop to remove. To torch it you just heat it up with the flame.
Old May 17, 2003 | 05:45 AM
pruizgarcia's Avatar
Love my y-pipe, best upgrade so far.
Pedro
Old May 17, 2003 | 01:50 PM
BadKarma99-4spd's Avatar
go get yourself some liquid wrench from autozone or one of those stores. soak the bolts for a couple of mins and they should come right off.
Old May 17, 2003 | 02:51 PM
mrb23's Avatar
or try WD40 first if you have some. Let it soak for a bit. I've found that wd40 works sometimes.
Old May 17, 2003 | 02:53 PM
pocketrocket's Avatar
Why not try those propane cans they sell at your local store, the ones for home projects (copper pipe welding, etc). Mmmmmm .... fire!
Old May 17, 2003 | 05:36 PM
WOODYMAX98's Avatar
Tried liquid wrench and wd40, and they wont come off. Any way to cut em off. I also tried to take of the cat shield and after 2 bolts breaking i just left the other 2 on. I dont know waht to do
Old May 17, 2003 | 05:40 PM
go to a mechanic shop and have them loosen the bolts with their air guns and then had retighten, also have them take out the ones you broke.
good luck
MaxLife17
Jun 27, 2019 01:37 PM
2kmaximel
Sep 16, 2015 03:19 PM
Violator
Sep 9, 2015 10:14 AM
