Idle RPM
Mine idles at 800 also. It use to idle at about 650, ever since I installed my MEVI now the idle is higher. I want to clean my throttle body though. When I took it off the old Intake manifold it was black but I didn't have any cleaner at the time. So hopefully once I clean that then my idle might go down.
How are you setting your idle by the way?
Guys, first off. thanks alot for your response
I changed the idle by turning the screw on the ecu. I think that this is specific to the 98-99 model but i might be wrong. When i reset the ecu the idle was too high (like 1100rpm) So I turned the screw and it lowered the RPM.
Unclejunebug
Apr 2, 2016 05:42 AM
Need help
23
Oct 2, 2015 08:56 AM
