Clutch pedal spring noise? Is that possible?
May 31, 2003 | 07:08 AM
I got in my car for the first time in a about 12 days and before I even turned it on, I pushed the clutch in. It made a "rusty, old spring noise" (if that makes any sense). I started the car and it still made the noise everytime i pushed the clutch pedal in and released it. I did some stop and go driving before I got to the highway and it kept making the noise. Then I drove for about 20miles on the highway and pulled over to listen for the noise again because I couldn't hear it at highway speeds. It had disappeared! I checked the clutch fluid level and it was full, like always. Any ideas what this is? I don't even know if the clutch pedal has a spring, but I just assume it does.
Thanks.
May 31, 2003 | 07:22 AM
Mine is doing the same thing as we speak. I was told to lube it up with vaseline or something like that, but I haven't had any time. But yes, on your clutch pedal assembly, there is a large spring on it.
May 31, 2003 | 07:23 AM
Is the spring on the cabin side or engine side of the firewall? I'll give that a shot right now.
May 31, 2003 | 07:57 AM
it should be on the cabin side just get some grease on it, mine does the same, no biggie
May 31, 2003 | 11:51 AM
Would vasoline be ok to use like suggested or should I use something else on the spring?
May 31, 2003 | 01:12 PM
i'd say use something else but vasoline should work
Jun 1, 2003 | 01:48 PM
what type of grease would be best for the spring?
Jun 1, 2003 | 03:34 PM
hmm not sure :
Jun 1, 2003 | 04:17 PM
anyone have an idea of what type of grease/lube to use on the clutch pedal spring?
Jun 1, 2003 | 05:11 PM
You could use wheel bearing grease if you have any laying around
