mod handeling first or the engine first
Old Jun 2, 2003 | 12:28 PM
delacruz_17's Avatar
96 auto gle
should i go for the handeling first (eibach, tokico illumina, front and rear sway bars) or go for the speed first (e.g. intake, muff. y pipe)
Old Jun 2, 2003 | 12:40 PM
ch13f's Avatar
I'd personally go with handling, it'd be a good idea to add some light 17x8s with sticky rubber to that list, you can have a great suspension setup but if your tires can't hold the road then its pointless. Low profile tires are pretty much essential.
Smithdogg1's Avatar
Why not a bit of both? Start with a FSTB and RSB for suspension. And a Y-pipe for performance (best back for buck mod out of the three you listed). Then lower it later on...
Old Jun 2, 2003 | 01:10 PM
Tatanko's Avatar
Bacon Lover
And somewhere in there, why not some clear corners?
Old Jun 2, 2003 | 01:15 PM
JerseyMaxima's Avatar
But thats absolutely first!
I say get suspension done first...
Old Jun 2, 2003 | 03:10 PM
Savage42's Avatar
I'm with you on that one.....suspension first, learn to drive it, then add power. BTW ch13f, how much difference did the Warpspeed Y pipe make? I just ordered one and I see that our cars are similar. I'm adding that and a RSB with week. Should be fun!
Old Jun 2, 2003 | 04:00 PM
ch13f's Avatar
^ You'll feel the y-pipe, I definatly noticed it more than my Injen intake. Adds a little rumble to the exhaust also.
Old Jun 2, 2003 | 04:08 PM
sandman1098's Avatar
Alot of horsepower is useless unless you can keep the car firmly planted on the ground....... I would go for som suspension stuff first, then a little bit of Power, then more handling.....
Old Jun 2, 2003 | 05:27 PM
Anachronism's Avatar
Rear Sway Bar is a little over $100, Front Strut Tower Brace is pretty cheap on Ebay (~$20) and they will make a noticable difference in handling. Y-pipe is around $200 depending on which one you go with and gives about 15 HP to the wheels , no other NA power mod can do that.
MAXSE5SPD
Sep 17, 2022 04:00 AM
ballerchris510
Sep 23, 2015 08:46 PM
seesole
Sep 14, 2015 12:38 PM
Maxima Pride '07
Sep 12, 2015 07:29 AM
A32goldylocks
Sep 2, 2015 06:39 AM
