I have never thrown a Cel until Yesterday - 0705, 0309 (???), 0304
Old Jun 2, 2003 | 03:07 PM
padam07's Avatar
I have never thrown a cel in my 98 Se auto until Yesterday. I knew I jinxed myself when I said that I was lucky not to have anything go wrong with my car. I checked the codes today and got a 0705 - EVAP Control System, 0309 - Undefined (I swear I counted it right, I don't know what it is) and a 0304 - Knock Sensor. What is the EVAP Control System? Is it hard to fix? How much is a Knock Sensor? Is it hard to replace? Thank you for an help in advance.
By the way my car has 77k and I bougth it last year off of my parents with 60K. The car has had no problems excpet maintenance parts(brakes, 60k service). Oil change every 3k.
Old Jun 2, 2003 | 06:05 PM
DougAtoms's Avatar
The knock sensor is bad and has been for some time. It won't cause a CEL to light just poor performance, many folks don't even notice the drop in performance. The Evap problem is most likely the canister vent control valve. Read the FAQ on diagnostics too.
Check this thread
http://forums.maxima.org/showthread....5&goto=newpost
Old Jun 3, 2003 | 04:09 AM
padam07's Avatar
Check this thread
http://forums.maxima.org/showthread....p;goto=newpost
Thanks Dougatoms!!! I will see what I can do.
Old Jun 3, 2003 | 09:54 AM
finny's Avatar
i just got the 03 09 and 07 05 also. I checked it with a scan tool and i think it came up 0440 and 1446 i'm gunna check it again when i go to work. i guess ill replace my gas cap and reset the light and see what happens. just wondering if you solved your problem and what it took to do so.
Old Jun 3, 2003 | 10:16 AM
padam07's Avatar
I googled the code 0309 and I came up with the EVAP canister vent control valve open and 0705 as the EVAP Emission System - Small Leak. I am assuming these have to do with each other so I ordered a new EVAp vent control valve from Courtesy Nissan for $27.86 plus shipping. I will replace that and see how it goes. I mine as well replace the gas cap also while I am at it. I will let you know if it works.
Old Jun 3, 2003 | 11:24 AM
REYMAX77's Avatar
i have these sensor going
ok i did my diagnosis i got a 03 04nock sensor0403hrottle position sensor,12,6 auto transmision throtle position sensor what to do can i fix it myself or how much to change??????
Old Jun 3, 2003 | 03:20 PM
plurco's Avatar
good news is that when you fix the KS is will seem like a whole new car.
Old Jun 3, 2003 | 03:55 PM
sandman1098's Avatar
0309 code is Evap Canister Vent Control Valve Open
Old Jun 3, 2003 | 10:56 PM
REYMAX77's Avatar
how much is a knock sensor ???? and is it easy to change.
Old Jun 3, 2003 | 11:22 PM
TN-Max's Avatar
i have had the CEL light on for past few weeks with the EVAP control system error as well as knock sensor; im not completely sure im following you guys on what i need to do to fix the EVAP control system part, please explain
Thanks for the help and sorry for my lack of understanding
Old Jun 4, 2003 | 04:43 PM
TN-Max's Avatar
bump, help please
Old Jun 4, 2003 | 04:57 PM
95GreekMaxSE's Avatar
exactly what kind of performace decrease is noticed when the knock sensor dies.. im in the middle of doing any maintenance work on the car (operation maxima restore)
Old Jun 4, 2003 | 05:05 PM
jt97gle's Avatar
same problem here.....any help is greatly appreciated.....thanks
Old Jun 4, 2003 | 07:39 PM
finny's Avatar
the evap control system code may be something as simple as a bad gas cap. check/ replace that for a cheap place to start. I did that yesterday and reset the light so well see if that takes care of it or not. otherwise the problem lies in the evap canister and/or canister valve. ill let yas kno how i make out
Old Jun 9, 2003 | 08:49 AM
finny's Avatar
was wondering how you made out with your codes, and whats the part number for the control valve to make sure i get the ring part. thanks
Old Jun 9, 2003 | 10:35 AM
taggate's Avatar
the knock sensor(part # 22060-30P00) you can get it for $124 at http://www.trademotion.com
and here are the directions "http://www.skippynet.com/maxima/knocksensor.htm"
jmlee44
Oct 2, 2022 02:13 PM
tarun900
19
Dec 20, 2021 06:57 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
Junebug1701
Sep 25, 2015 01:54 PM
