best method for sticking antenna?
Old Jun 10, 2003 | 01:54 PM
FLO_BOY's Avatar
not sure where my post went.......
hello org.ers!
my automatic antenna is not going up all the way.
i'm sure after I grease it up a little, all will
be well, but, how do I go about greasing it?
I've added white silicone grease to the outside
of the antenna, but, no real luck...
-- should I use a more liquid grease/oil?
-- can I grease the antenna from the inside?
l'il help please!
FLO_BOY
Old Jun 10, 2003 | 01:58 PM
Nismo3112's Avatar
Custom User Title
White Lithium Grease
Old Jun 10, 2003 | 02:00 PM
FLO_BOY's Avatar
err...that's what I meant -- lithium, not silicone.
spraying it on the outside did, well, next to nothing...
I'm starting to think I should use something a-la-WD40
FLO_BOY
Old Jun 10, 2003 | 02:38 PM
MyGray96SE's Avatar
You can get new antenna masts on ebay for cheap. Using lithum grease isn't a good thing. Dirt and other crap will stick to the antenna and will gum up the mast. If you get a new one, wash it once in a while and use a dry (graphite) lube once in a while. That should do it...
Old Jun 10, 2003 | 10:35 PM
KsuMax's Avatar
Cheesing away...
My camry use to have that problem, I just used graphite lube on it every once in a while and it worked.
Old Jun 11, 2003 | 06:11 AM
Dasyce's Avatar
the only maintance your supposed to do to the antenna is clean it with warm water, i think is stated in the owners manuel..
Old Jun 11, 2003 | 09:18 AM
jaysway's Avatar
I used WD40 on mine and it seemed to work fine... i just now hafta re-apply every now and then... but that takes all of ten seconds
chisam14
Nov 6, 2018 08:56 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
DBear
Sep 14, 2015 08:33 PM
Violator
Sep 9, 2015 10:14 AM
