running rich or lean??????
Old 06-11-2003 | 08:42 PM
billy_corgan's Avatar
what does it mean to be running rich or running lean? how does each affect the performance of your car? how can you tell? how can you fix? i probably sound dumb but someone told me it smelt like i was running lean and i wanted to know why.
Old 06-11-2003 | 11:26 PM
BlueC's Avatar
wat
since no one is replying to your thread, i'll help you out...
running rich = more fuel than air, ratio
Usually isnt a huge problem when you're running rich, I know running lean is more severe. if you're not getting enough air, or you're getting too much fuel, you'll be running rich
running lean = not enough fuel than air ratio
If you're running w/o much fuel getting through, and a lot of air is going through, you are running lean. i.e. if you turbo your car and dont upgrade the injectors/fuel pumps, dont get guages/AFC controller, etc, you will most likely run lean, wich is very bad and sometimes leads to detonation. Look what happened to cassidy, he ran lean and blew his motor.
Just get some gauges or something if you're concerned about running lean/rich. If there is a problem, go out and buy an AFC controller or something, and it should fix it.
Thats about as much as i know, dont quote me on much though, cause i could be wrong. Im just not sure about running rich, how it affects your car and everything, etc. Hope that helps!
Old 06-12-2003 | 05:23 AM
96BLUMAX's Avatar
Too rich and youll flood the engine.
Old 04-24-2009 | 01:04 PM
pmohr's Avatar
No more Maximas...
Originally Posted by stk
if you car dies out when you keep it on drive, does that mean it runs rich ?
Seriously? A 6 year old bump for this?
Newbie thread, learn how to use it.
No, it doesn't necessarily mean anything about your AFR.
If you're having an issue, post in the newbie thread, and it can be properly diagnosed.
You're not even in the right damn section, go to the 5th gen subforum.
MAXSE5SPD
09-17-2022 04:00 AM
JoshG
51
09-21-2015 10:41 PM
ajahearn
09-19-2015 03:03 PM
ballerchris510
09-10-2015 09:35 PM
AT978
09-06-2015 10:31 PM
Quick Reply: running rich or lean??????
