Squeaky Strut Mount ?s
My car now has 93k miles on it and the front right strut mount is making a horrible squeky noise everytime I go over a bump or even when I make a turn and it leans. I currently have some H&Rs that I'm waiting to install when I get my KYB struts. My question is should I just replace the strut mount with a OE/or whatever pepboys can get? Or is there a better kind of strut mount available? What are my options, pros/cons? All I know that you can get with the KYB are the dust covers, which I'm not getting. Unless someone gives me a good reason. Thanks for listening and for the advice!
Are you sure it's the mount and not the strut itself? A blown strut will cause excessive body roll, not a broken mount per say. Look at the mounts from the engine compartment, they should look clean, no torn up rubber inside them and the strut bolt should be securely centered in the mount.
KYB Dust covers -
1) Shorter bump stop to give back suspension travel on a lowered vehicle.
2) Cheaper then OEM $$$
3) Available at just about any auto parts store
4) May last longer then OEM dust covers
KYB Dust covers -
I took a look and the rubber is cracked. Plus the strut mount prong thingy is leaning against the side. I pushed down and saw/heard to problem. It is the strut mount. Are there any aftermarket/peformance strut mounts available? Other than the dust cover are there anymore supension accessories? Thanks njmaxseltd!
I've got a set of KYB strut mounts I could sell to you cheap. PM me for details if your interested.
As far as other suspension accessories. Get the Eurathane(sp?) sway bar end link bushings from Courtesy Nissan. Your old bushings are probably all compressed by now anyhow.
I have the same problem on the drivers side. My stut mount is messed up and causes a squeaking sound. I know its the strut mount because I checked under the hood and when I turn the whell you can see the top spindle moving, when it shouldnt be. So I bought one online for $35.
I hear there are some KYB strut mounts available. Are these any better than the OE ones? And will they work with stock struts? I'm getting KYB AGXs but not any time soon. I'd like to have the KYB strut mounts if they improve your suspension or last longer I'm just not sure if they would work with stock struts. Thanks.
A good mount will not move (actually, just a very, very small amount).
Tim
Here is the Link where I bought Mine from.
http://www.tirerack.com/suspension/k...unt+%28each%29
knight_yyz
11-01-2015 01:34 PM
