Bomz CAI instructions or help?
Old Jun 12, 2003 | 03:04 PM
Allen's Avatar
I just got my Bomz CAI today and it came with no instructions. I guess it's because it's a fairly simple mod to do, but I really don't want to make any mistakes and could use some help. Do any step-by-step instructions exist? I'm supposed to drill into the fender to fit the filter, right? Where exactly would I drill and what is it supposed to end up like?
Old Jun 12, 2003 | 03:14 PM
97blackSE's Avatar
basically you just put the little pipes all together, and make a hole for the intake to fit into the fender wall! its relatively easy, but since i don't actually have the bomz, i will let someone post actual instructions...have a splendid day
Old Jun 12, 2003 | 04:06 PM
Allen's Avatar
does the car have to be raised for the filter to screw in from underneath?
Old Jun 12, 2003 | 04:10 PM
Allen's Avatar
oh yeah, and does the filter come oiled already, or do I need to do that? sorry i'm a n00b :P
Old Jun 12, 2003 | 04:40 PM
sx7r's Avatar
yes, you'll have to jack up the car, undo the fender liner a little to reach up in the fender well to tighten the filter onto the pipe. assuming the piping for the kit is 3", you go buy a 3.25" hole saw adapter for your drill. remove the battery, battery tray, unbolt the fuse box to give yourself room to drill. connect all the pipes and see where it ends up. mark the location you need to drill. make sure the battery tray will be able to fit back on once the pipe goes through the hole you are about to drill. then drill. clean up all the metal shavings when you are done. the rest is self explanatory. As for oiling the filter, it depends on the material. If it's cotton gauze type material, it should come oiled already. If it's paper-like material then it won't be oiled. good luck.
Old Jun 12, 2003 | 05:32 PM
Allen's Avatar
ok thanks and what do i do with the sensor (0xygen sensor?) that was in my stock airbox??
Old Jun 12, 2003 | 06:06 PM
sx7r's Avatar
there should be a hole in the pipe for you to place the air temperature sensor.
Old Jun 12, 2003 | 07:16 PM
Allen's Avatar
there is none =\ i'm getting worried, does anyone know where the air temp sensor goes on a bomz CAI ??
Old Jun 12, 2003 | 07:49 PM
trutank
SKIt
EEEYEAHH!!!
Old Jun 12, 2003 | 07:56 PM
2KxSEx's Avatar
There's a hole in the mid pipe that is plugged with a rubber plug. Just pull the plug out and put the sensor in there.
Good luck!
Old Jun 12, 2003 | 09:18 PM
jargoone's Avatar
I didn't. I have PR, not this one, but I did it just fine without jacking it up. I pulled a couple of the clips, undid a couple of the screws, and was able to bend the liner away to get the filter on.
Old Jun 12, 2003 | 09:36 PM
BadKarma99-4spd's Avatar
go to maximadriver.com they have a write up with pics.
good luck
Old Jun 13, 2003 | 12:25 AM
Allen's Avatar
good luck
where?
Old Jun 13, 2003 | 05:39 AM
jargoone's Avatar
where?
Look no further than the .org:
https://maxima.org/shoptalk/sub_modi...ai/index.shtml
The only thing this write-up doesn't have is the template for the hole. I ran into the same problem recently when I bought a used PR CAI. You can tell close enough by looking at the pictures. Drill your pilot hole for the hole saw, then place the hole saw in the pilot hole, underneath the vehicle (where the filter will reside). You can easily tell if you'll hit anything. Once you see you wont, go back up top and cut away.
Old Jun 13, 2003 | 11:01 AM
where?
my bad, he must have not gotten everything up on the new site yet.
Old Jun 13, 2003 | 12:19 PM
sx7r's Avatar
back in the day, i had a 3" drop. it was necessary for me.
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
Sep 27, 2015 08:37 AM
A32goldylocks
Sep 16, 2015 01:33 PM
