Top speed of each gear on a automatic with JWT ECU (7000rpm)
Jun 13, 2003 | 08:29 AM
I was wondering what the top of each gear is now that the redline is 7000 rpm. I think I almost saw 90mph in 2nd gear! Anyone know the numbers for sure?
ZuM
Jun 13, 2003 | 09:31 AM
i can hit 80-82mph in second with my stock ecu so i should think 90+ is within range. nothing like having an auto max
Jun 13, 2003 | 01:29 PM
See what your speed is at 3500rpm in each gear and then multiply that speed by 2.
Jun 13, 2003 | 01:45 PM
Cool! I wasn't sure if it worked that way. But I guess it does.
Quote:
Jun 13, 2003 | 02:20 PM
Quote: See what your speed is at 3500rpm in each gear and then multiply that speed by 2. END Quote:
NO WAY, man I would NOT want to line up my max against yours !! And the Chariot is no Slouch !
Jun 13, 2003 | 03:11 PM
Cartest says you'd reach 48, 89, 139, 203 @ 7000rpm in each gear assuming you have tires that are stock sized.
Jun 13, 2003 | 03:23 PM
Great! But I'm running 225/55 on the stock 16s. Could you give me the numbers for those? Excellent, thats exactly what I was looking for though. I need a general idea what gears I can downshift in to and what speeds.
Quote:
Jun 13, 2003 | 05:39 PM
With different size tires, your actual physical speed may change, but the speed you see on the speedo will be the same. So, his numbers still apply.
DW
Quote:
Jun 13, 2003 | 06:49 PM
203 mph?! has any one really had there max anywhere close to that??
Jun 13, 2003 | 07:05 PM
doubt it since our cars top out a 140ish, even with JWT ECU they would only be in the 150's maybe...
Jun 13, 2003 | 08:20 PM
can't get it past 199,,,is something wrong??
Jun 13, 2003 | 09:11 PM
Yes, check your knock sensor. 200mph should be easy with a perfect running car. Probably your knock sensor or maybe speedo error. Do you have Spiral Max yet?
Quote:
Jun 13, 2003 | 10:41 PM
Quote:
80?
I hit 45 in 1st then 75 in 2nd then 110 or so in 3rd..
Are you sure your hittin 80? Maybe youre speedo is wrong?
Jun 14, 2003 | 06:09 AM
i can definatly hit a speedo indicated 80mph. i've done it time and time again.
Jun 14, 2003 | 10:56 AM
You can def. hit a speedo indicated 80mph in 2nd gear. There is tach error. So you shift after redline.
Jun 14, 2003 | 12:36 PM
i've found that the best way to race an auto is to pay attention to the speedo for gear changes rather than the tach. it's usually way off when you're up in the higher revs. or just learn when and where your tach's off
Jun 14, 2003 | 07:02 PM
C'MON, You're sayin I can go 200 mph in my 96 gxe????I had it to 130, it wasnt floored though.
Jun 15, 2003 | 10:25 AM
Yes you can go 200mph if you had around 430-450whp .
Jun 16, 2003 | 05:10 PM
So what mph can you reach stock I am asking...and I will try it soon going on a nice long ride to Fla soon!
