ECU programs
Old Jun 15, 2003 | 06:41 PM
coryf's Avatar
ECU programs
just curious. my check engine light came on the other day, not blinking. so i had it checked, and it was throwing codes that the knock senor and an O2 sensor was loose. i tightened them, and it stayed off. then it came on again about 3 days later. i dont want to pay $50+ for someone to check the computer. does anyone have the software for a 96 Maxima GLE?? or any advice on the matter??
Old Jun 15, 2003 | 06:59 PM
Nismo's Avatar
do it yourself free. instructions http://forums.maxima.org/showthread....hreadid=104931 btw change that KS and get back your power
Old Jun 16, 2003 | 12:31 AM
I30tMikeD's Avatar
Re: ECU programs
Did not know there was a code for a loose o2 sensor
Are you sure the code for for a "loose" sensor?
Old Jun 17, 2003 | 09:24 AM
coryf's Avatar
i should clarify, it wasnt a loose sensor. it said heated O2 sensor.
so i cleaned, and tighten the sensor connections. because at the moment financially thats all i could afford to do.
Old Jun 17, 2003 | 03:17 PM
I30tMikeD's Avatar
Well, there is no harm in trying to clean it before having to replace it. If it came back then your going to need to replace it. o2 sensors can be had for around $65 online.
Also, what do you want "software" for and how do you think it's going to help? You got a code for a bad o2 sensor, tried cleaning it but it did not work, so now it needs to be replaced.
Old Jun 17, 2003 | 04:00 PM
asf4life's Avatar
drivewire.com. has good prices for oem connector replacement sensors
gigabyte
Jan 6, 2017 06:05 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
Dasmith
Sep 23, 2015 08:28 PM
QueensMAX
Sep 15, 2015 04:14 AM
