Aftermarket seats - Help!
Old Jun 22, 2003 | 01:31 PM
Moreau's Avatar
Ok so i got 2 new aftermarket racing seats for my 98. I have the leather with the power seats and side airbags. What precautions should be made in taking out the factory seats? Also, my seats came with sliders, but no brackets. The stock power rails are mounted 17" apart, and my aftermarket seats bolt up 16" apart. anyone had a similar problem? Is there a bracket I can fabricate to make the seats fit? thanks
Old Jun 22, 2003 | 03:56 PM
Torgus's Avatar
getting rid of the leather for cloth racing seats? other then maybe losing 50lbs tops which = no increase in the 1/4. why do it. i'v only sat in a few racing seats and while they do hug more then the stock leather ones might....i find them uncomfortable and hard. any pics of the seats your getting? how much did they cost you? in my opinion racing seats belong in racing cars. but if you dig em then throw em in. i just don't understand them.
Old Jun 22, 2003 | 06:32 PM
Moreau's Avatar
well i find the stock ones uncomfortable, and my stock seat is all messed up and noone can fix it for cheap, so i got these seats, plus it was a good deal. but anyone willing to help?
Old Jun 22, 2003 | 07:23 PM
NightRider's Avatar
Since you have side airbags, you'll have a problem with your airbag light blinking.
Old Jun 23, 2003 | 06:45 AM
Torgus's Avatar
racing seats in a 4 door family sedan?!??!
thats like putting racing seats in some small import economy car!!!
fuqkin
Old Jun 23, 2003 | 06:51 AM
Ceasars Chariot's Avatar
Old Maxima Legend
i would take racing seats, something to hold you in place plus get that 50 pounds of weight knocked off. its true some of us maxima owners belong in 300 ZX TT or 350 Z track models..
Old Jun 23, 2003 | 06:56 AM
Torgus's Avatar
Ceasar then maybe your in the wrong car? i know i belong in a skyline but im not about to go buy a skyline bodykit.
Old Jun 23, 2003 | 08:35 AM
Moreau's Avatar
ok, buddy, u say racing seats in a max are Gay, but u have altezza tail lights. a mod which costs almost as much as my seats, and those do nothing, and nothing says gay more than a pair of altezzas, hey lets make a webpage full of pics of stuff u dont have. get a life buddy, just cuz ppl are out there doing things doesnt make the man. and i sure as hell could care less about if u think the seats are rice, cuz nothing says rice more than altezzas and white light bulbs.
Old Jun 23, 2003 | 10:55 AM
nismology's Avatar
Why are you asking him "why do it"? He already did it. Deal with it. He just wants to know to put them in. And as far as racing seats in an import economy car, you obviously haven't ridden inside one with suspension work. Then you'd see the need for seats with more lateral support. Sorry Moreau, I can't help you, but I just had to put this flamer in line.
Old Jun 23, 2003 | 10:59 AM
ESLEECK
BURN! I dont like altezzas either
Old Jun 23, 2003 | 11:04 AM
Quack 2x's Avatar
As far as the brackets go, you can have a set machined for you at a metal shop or machine shop. Just make sure you use good quality metal... I've seen thick angle iron used because it's pre-bent, can be cut to any length, and can be drilled out to match the mounting holes in your car (assuming they are spaced correctly... you may need to do some drilling or welding to attach them to your floorpan). Of course, if you go this route and don't use sliders (assuming your seat came with them), then your seat will pretty much be stuck in that position unless you drill a series of holes for adjustment.
Zirafa's Avatar
I don't know if these guys have what you need but this is all I could find:
http://www.corbeau.com/bracket.shtml
Old Jun 23, 2003 | 11:21 AM
amixam98's Avatar
Needs non-Maxima Friends
Old Jun 23, 2003 | 12:54 PM
krismax's Avatar
Father of the 00 VI
I put R-1 racing sports in my car but it was a nightmare i have advice for people if it doesnt have direct bolt in brackets dont buy the seat. If he bought adjustable seats he will not save that much ,mine with custom brackets weigh about 40lbs and my stock bolt locations were destroyed my seats suck . When i get some time i will have some stock seats out of a del sol installed and throw my seats in the trash.
Old Jun 23, 2003 | 01:08 PM
Moreau's Avatar
yeah it has the sliders with the seat, but the stock power rails are mounted 17 inches apart and the seats is 16" apart. so my guess was the easiest way would be to make a bracket or adapter to allow the rails to be mounted to the stock rail mounts, therefore, i would not need to buy brackets or permanently change anything on the car itself. does this sound like it is possible?
Old Jun 23, 2003 | 02:37 PM
1MAX2NV's Avatar
Do a google search for Wedge engineering or Wedge metal works. If it's a popular seat..ie Sparco Tornio or Recaro SRD...they have custom brackets for the maxima.
Old Jun 23, 2003 | 03:03 PM
krismax's Avatar
Father of the 00 VI
I had sliders with my seats to but if you start cobbing the seats you will be sorry, if you cant get brackets get rid of the seats or have a good shop do it.
Old Jun 23, 2003 | 03:20 PM
Quack 2x's Avatar
You're thinking of making two 1/2 inch thick plates that you can mount to the seat rails? That would probably work, that way you won't be drilling or welding to your car. Everything else should work, sliders, etc... all you would have to do is take up that extra inch of space.
Aloha,
Quack2x
Old Jun 23, 2003 | 08:03 PM
ESLEECK
yup with the right measurements and a decent machine shop , you should be straight
sliptap
Sep 30, 2015 05:57 AM
uttadms31
Sep 30, 2015 05:24 AM
salty318
Sep 29, 2015 01:21 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
