injen intake ? different makes???
Old Jun 24, 2003 | 10:00 AM
RI-Max's Avatar
ok guys i have a injen intake off a 98 maxima i bought it used. i have a 96 max. i have it installed and have had a starting problem eva since i installed my intake. had it wabout 6 month on. .i heard they make different ones for each year? from 95-96 & 97-99 is this true and whats the differents between those?
Old Jun 24, 2003 | 10:48 AM
dizmax96's Avatar
injen intake
wat model number do you have? i have the rd 1930 which is prolly the same one you have. ive had mine for like a year now.. and i dont ahv problems wit starting. i dont think the intake is touching the starter or anything taht would cause a hard start or anything??? is the filter touching the transmisson cable at the bottom? dont think that would matter.. but still. how many miles do you ahve on the car? you prolly need a new starter. check it. peace
DiZ
Old Jun 24, 2003 | 10:52 AM
njmaxseltd's Avatar
Intake Air Temp sensors are in the 97-99 years.
Old Jun 24, 2003 | 01:30 PM
RI-Max's Avatar
then would the intake air sensor casue hard starts??? how do i find the part number on the intake.
ps: i have a new nissian starter (upgrade high TQ more teeth etc. starting problem got alot better after that. but still have it sometimes
Old Jun 24, 2003 | 01:55 PM
njmaxseltd's Avatar
No.
A failing crank or cam position sensor will cause hard starts.
So will an out of spec Engine Coolant Temp Sensor.
You can also try to cleaning your throttle body.
Go to www.motorvate.ca for detailed instructions.
Old Jun 24, 2003 | 05:24 PM
RI-Max's Avatar
Originally posted by njmaxseltd
No.
well i already changed both crank sensor pos,ref. just didn't change the cam sensor tho but no check engine light tho.
so i should just leave air temp sensor alone then???
Old Jun 25, 2003 | 10:21 AM
REYMAX77's Avatar
OK
IF U KEEP HAVING PROBLEMS AND YOU ARE INTERESTED IN SELLING IT I WILL GET IT OFF YOUR HANDS. SO YOU CAN BUY THE RIGHT ONE FOR YOUR CAR. I HAVE A 98GXE. THANKS
220k+ A32
Sep 11, 2015 02:18 AM
Maxboy23
Sep 9, 2015 10:37 AM
A32goldylocks
Sep 2, 2015 06:39 AM
