black smoke at start up
Old Jun 26, 2003 | 05:32 AM
NotNew!!NewSN!!'s Avatar
I know this has been discussed before...what does it mean when u have a little puff of black smoke at initial start up and thats it...thanks.
Old Jun 26, 2003 | 05:35 AM
PCGuRu2K's Avatar
Change your oil
Old Jun 26, 2003 | 06:05 AM
njmaxseltd's Avatar
Valve guides are leaking.
Old Jun 26, 2003 | 10:52 AM
well that sucks...any more detailed info about what valve guides are?
Old Jun 26, 2003 | 11:03 AM
Miasma's Avatar
if oil is leaking, the smoke will be blue
how black is the smoke? like diesel black?
i would think it has to be an oil issue. have you tested your compression? valve stem seals will not affect compression, just rings and valve seats.
Old Jun 27, 2003 | 05:42 AM
it seems like more of a carbon issue, like after u clean ur throttle body when u rev u will have a good amount of black smoke for a while...its not thick black, its literally just a lil puff cloud sometimes on intitial startup....maybe there is carbon settling in my exhaust and shooting out at initial startup....
Old Jun 27, 2003 | 06:07 AM
dave harms's Avatar
Rule of thumb:
Blue : Oil
Black: Gas
White: Coolant
Maybe you car runs 'rich' for a second when you start it.
Maybe it's like you said, carbon dust comming out of the exhaust.
Drive her at about 5k rpm, (to purge exhuast) then shut off, and restart a minute later, check exhuast... also restart it about an hour later (after high rpm run) and watch exhaust.
Does it always do it at start-up? and is it to the same degree?
mvm062
Nov 30, 2020 09:00 AM
Maxima.KsA
Sep 8, 2015 11:33 PM
A32goldylocks
Sep 2, 2015 06:39 AM
FlaMark
Aug 21, 2015 11:06 AM
Balkins
Aug 12, 2015 06:39 AM
