lost acceleration
Old Jun 28, 2003 | 08:46 PM
MyMax96Se's Avatar
lost acceleration
My check engine light when on and found out it was a bad knock sensor and a rear engine O2 sensor, which I can replace. However recently, my car doesnt accelerate properly. WHen shifting from 1st to 2nd it seems to bogged down. Almost a stuttering affect acceleration. What could cause this. Someone mentioned that if you have moisture in the engine that this could cause it. I do have an CAI which goes down near front left wheel well. If this is true, anything I can do to fix..
HELP
Old Jun 28, 2003 | 09:00 PM
mzmtg's Avatar
Minister of Silly Walks
Fix the O2 and KS. This should clear things up
Old Jun 29, 2003 | 04:45 AM
D1NOnly34's Avatar
o2 sensor is the piggy back code, fix it/clean it/repair it..do whatever you have to do, but once that problem is solved, the KS code will usually go away and you will most likely gain back your acceleration.
gigabyte
Jan 6, 2017 06:05 PM
D Mason
Jun 21, 2016 04:43 AM
Need help
23
Oct 2, 2015 08:56 AM
jcvgn
Sep 10, 2015 08:03 PM
MidnightMaxima_22
Sep 6, 2015 01:18 PM
