HELP-brake groan when backuing up
Old Jun 30, 2003 | 07:05 AM
largestal's Avatar
Put Raybetos Quiet Stop pads on the rear on Saturday. Cleaned, scrubbed and regreased everything. Brake pads are great, stop nicely and no noise - except when backing up.
They don't make noise first thing in the morning when they are nice and cold, but by the time I drove to the office this morning and backed into my parking space - it sounded like a city bus groaning when it stopped.
Did I miss something? I pulled both mounting pins and cleaned and regreased them. New pad clips. Used the Raybestos shims and gave the back of the pads a coat of brake quiet.
Any help would be appreciated.
Old Jun 30, 2003 | 07:58 AM
I30TinME's Avatar
This site will give you the symptoms but not the cure.
http://www.nissan-techinfo.com/nissa...9.asp?mscssid=
"This incident can be caused by a slight tension on the parking brake cable resulting in the brake pads not withdrawing completely from the surface of the rotors after release of the brake pedal. This contact results in a low frequency groan or humming noise."
Now you can purchase the TSB (NTB99031) which should outline the factory "cure" but I am curious if someone might have this information. One would imagine it has something to do with the parking brake cables, but again, would be interested in the factory cure.
Old Jun 30, 2003 | 12:16 PM
sbmax95's Avatar
I have a similar problem with my left rear caliper. It seems to become seazed after long or hard driving. It's not totaly though,just enough to make a loud humming sound. I got in there to see if it was the
E-brake. I unhooked that and it still does it. I also notice a little more brake dust on that wheel. So I will more that likely have to replace that caliper. That may be what yours are doing beause I notice mine doing it a little at a time as well.
Old Jun 30, 2003 | 12:22 PM
Maxx Knight's Avatar
I don't know about both cases, but sbmax95 it sounds as though your rear calipers are going bad or were not installed properly. The piston inside the rears has to be screwed in. Both of my reasrs went bad. Had meinkei rip me off for the first one, then I got one from advanced auto parts and replaced it the other myself. I had the same symptoms as both you guys and they just progressed. The rim would get really hot and then started dragging the wheel at it worst point.
Old Jul 2, 2003 | 10:32 AM
largestal's Avatar
I wonder if I put a light coating of grease on the surface of the clips on which the pads ride to keep them from catching?
Thanks for the TSB. I hate spending the cash, but I might have to. Strange thing is that it only happens in reverse and only when I apply the brakes, not after I release them.
Then again, new calipers might be in order. Sad part is that the car only has 37K on her.
Old Jul 3, 2003 | 08:26 AM
largestal's Avatar
bump
Old Jul 9, 2003 | 09:51 AM
Turbobink's Avatar
Having just spent $450 for a four wheel brake job and an alignment at the dealer, the development of this symptom in my car as well has kinda ****ed me off...
Old Jul 9, 2003 | 10:12 AM
blizz20oma's Avatar
I'm so hood
I don't know if these are the same issue. The sticking caliper noise is a constant grinding. largestal's seemed to me like it's an abrupt noise when he stops, or perhaps releases the brake pedal. I've noticed this in a few automatic cars (it especially reminds me of my roommates Grand Cherokee).
And in my car...but really only when I release the pedal on an uphill incline, or come to a full stop on a downward hill.
largestal, tell me if I'm wrong. The noise I experience is very city-bus like
Old Jul 9, 2003 | 11:23 AM
largestal's Avatar
city bus - yes. But only when I back up. It vibrates enough to shake the mirror. It gets louder when I hit the brakes.
I am going to tear it apart tonight and check to see if the pads are sticking or if it is caliper related. First time this has ever happened to me and I am stumped.
Old Jul 9, 2003 | 12:16 PM
maximafever's Avatar
i had that same problem it feels like the car is locking up but after awhile the problem went away i'm thinking that I tightened the ebrake cable too tight and it finally loosened up.
05RLS2
Sep 27, 2015 09:24 PM
ItchyRichy
Apr 12, 2003 08:50 AM
Larrio
Jun 28, 2002 11:03 AM
WasabiMax
Feb 19, 2002 09:42 PM
JCrwu
Dec 20, 2001 10:00 PM
