Indiglo guage install help!
Old Jul 8, 2003 | 05:04 PM
Maximum96's Avatar
I just installed my guages and the speedometer needle is stuck, when i drive it stays at zero. It is because it is rubbing against the stock guages. Im sure alot of u had this problem, any ideas on how to make the needle slide easier???
Old Jul 9, 2003 | 02:30 AM
jcy98maxse's Avatar
Turbo is too much fun!
make sure that the gauge is not rubbing or remove the stock gauges.
Old Jul 9, 2003 | 02:35 AM
Tino98max's Avatar
im having the same problem all my needles are fine, except the needle of the speedometer, which only moves after a while, and seems about 20 miles off per hour, any suggestions guys also, let me know thanks, i dont know if i need a new cluster or not, just because all the other needles are fine?????
tino
Old Jul 9, 2003 | 04:36 AM
geo1317's Avatar
use double sided tape to hold the faces down.
Old Jul 9, 2003 | 05:25 AM
Pizatt's Avatar
Either use double sided tape or a little bit of super glue at the edges of the gauges. Your problem is the gauges are not held all the way down. Figure out how to hold them down all the way and your straight
Old Jul 9, 2003 | 05:56 AM
Maximum96's Avatar
i used krazy glue at the edges of the guages, but no double sided tape, that might be the prob. i cant remove the stock guages because i need those little needles that hold the speedo and rpm needle at zero. My indiglo guages dont have that needle
Old Jul 9, 2003 | 08:35 AM
JPMax's Avatar
What's next!?..
Did your new faces have the holes for the screws in the middle of the gauges? If not, you could try drilling holes for them. Just check the back of them first to make sure you're not drilling into something important.
I had the same problem on my 95 at first so I just made some holes myself.
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
rnb754
Sep 14, 2015 11:39 PM
