HELP!!! Exhaust system layout question
Old Jul 16, 2003 | 05:47 AM
maximabiz's Avatar
Hey All,
Can you please help me understand the exhaust layout for a 1997 Maxima SE. I got a small leak, and trying to pin-point what part is the culprint.
Let me take a stab at it, and please let me know if I am wrong.
Off the header is the "front converter".This is the piece with the honeycomb flex pipe in it.
Next comes the rear converter, I think???
Then the mystery, what is the longer cylinder shaped object after the rear converter? Is this a front muffler or resonator?
From there the plumbing goes to the rear and to the rear muffler hanging under the trunk.
Guess in a nutshell my question is, aside from the front converter and rear muffler, what are the two units in between.
You can use Courtesy Nissans diagram as a example:
[URL=http://]http://www.courtesyparts.com/A32_O2-sensors.html
On the diagram the area of confusion is the unit where the 95-96 rear sensor plugs into. Is this the rear converter or resonator? And the second thing is the following unit that is cut off in the picture, it looks like a cylinder. Is this a front muffler or is this the cat.
Thanks in advance for any assistance.
MaximaBiz
Old Jul 16, 2003 | 06:29 AM
maximabiz's Avatar
I think I may have figured it out.
Y-Pipe is the front converter piece
Next is the converter
Then the B-Pipe
Then the muffler
So the only question is, what is the chamber on the B-pipe for? Is it a muffler or resonator?
MaximaBiz
JRod28
Dec 29, 2023 09:56 PM
rbuswell
Nov 12, 2016 04:11 PM
stromm
Aug 27, 2015 04:13 PM
maxinout93
Aug 20, 2015 02:17 AM
wyobbagy
Aug 15, 2015 02:28 PM
