What color should I paint my Calipers ?
Old Jul 18, 2003 | 12:07 AM
Ceasars Chariot's Avatar
Old Maxima Legend
What color would look good on a white maxima ?
yellow, red, silver ?
any ideas ?
any pics of white maximas with painted calipers ?
Old Jul 18, 2003 | 03:00 AM
Max Noob's Avatar
black or gun metal..
Old Jul 18, 2003 | 05:57 AM
Bags's Avatar
VG Ridah's Biatch Hoe
black or the color of the car...
Black for ease of cleaning and NOT seeing dirt
Old Jul 18, 2003 | 05:58 AM
JamesAvery's Avatar
Re: What color should I paint my Calipers ?
I say go with silver
any ideas ?
Old Jul 18, 2003 | 06:02 AM
97GLES's Avatar
Re: Re: What color should I paint my Calipers ?
black
Old Jul 18, 2003 | 06:41 AM
njmaxseltd's Avatar
Silver or Black. Make them clean looking, don't make them stand out with flashy rice colors.
Old Jul 18, 2003 | 06:51 AM
clee130's Avatar
Bright neon green
Old Jul 18, 2003 | 07:28 AM
araffio's Avatar
red
Old Jul 18, 2003 | 07:31 AM
S103100F's Avatar
96 perl white<------ same problem i dont know
Old Jul 18, 2003 | 07:41 AM
Gen8888's Avatar
Red would look nice, stands out. Also how did you guys prep the area for painting the caliper? Which areas should I stay away from painting, rotors, pistons? I plan on leaving the calipers on and painting them. Thanks for the help in advance.
Old Jul 18, 2003 | 09:09 AM
araffio's Avatar
I just repainted mine last night, after 2 years the red was fading. I wrap a plastic bag around the rotor and pull it tight around the edges of the caliper, The I lightly spray the caliper from a few inches away with very thin coats. This avoids overspray and dripping.
Use some brake cleaner and a wire brush to get rid of all the dirt first.
Old Jul 18, 2003 | 10:21 AM
aznsap's Avatar
is it hard to remove all the caliper parts you want to paint and take them off the car? or do you have to leave it on (if you removed the brake fluid hose i take it brake fluid would leak out)?
Old Jul 18, 2003 | 10:45 AM
CheshireCat76's Avatar
rojo
Old Jul 18, 2003 | 11:39 AM
KFL007's Avatar
It's not hard just more time consuming, it's not totally necessary to remove them. Yes, some fluid would leak out, just plug the line with something then no problem but some air has entered the system bleed brakes. It's easy just jack up car clean up calipers, wire brush, sand paper,wash n dry up. Then just paint with your choice of caliper paint,I tried the G2 Black caliper kit was ok, but the shine wasn't there my friend used it on his maxima as well.
I'm now using duplicolor graphite grey wheel paint, yep meant for wheels but so far has worked well with the calipers. I lightly sanded a bit and then sprayed about 3 coats of it. Looks very clean and gleams and night cause the paint contains light metallic flakes.
The color overall is well hot, its not super flashy or plain black/silver has a little glimmer. You could also probably add clear coat on top of it and it will give it even more shine..I may take a crack at that I think that color would be perfect for a white car nice contrast.Yellow is too loud, red is not as loud but getting there since its a white car.Silver is clean and good but doesn't standout, black gets super dirty after rain,dust,dirt. Good thing about grey is that brake dust is greyish color so it blends in and appears clean.
I can get some pics over the weekend of some calipers as I will be tackling my friend's max EGR code.
Old Jul 18, 2003 | 02:50 PM
taeMAX97's Avatar
white... i just repainted mine few days ago but messed up. i was being too impatient. gotta work on it again but white on white is the best.
Tae
Old Jul 19, 2003 | 07:56 AM
Mojo Risin's Avatar
i just painted mine blue... it looks real clean. i don't have any pics, but that will be my next project. i have a sort of blue and yellow theme goin on my white max... it's lookin good too!
Old Jul 19, 2003 | 10:09 AM
Dave Holmes's Avatar
I tried white on my '97 Arctic Pearl White. Didn't look right because the white didn't match the car close enough, and it was too flashy (luckily only did one caliper). Then I went with red for a year til it got old. Now they are "Real Blue" (name of color), and I get comments on them all the time (from older people especially). They are not flashy, just enough to catch your eye; very subtle detail. These are behind the stock SE 16's. All in all it is a conservative, but detail oriented look. I may try to attach a pic later.
Dave
Old Jul 19, 2003 | 11:14 AM
Mojo Risin's Avatar
as will i...
Old Jul 19, 2003 | 03:15 PM
ScubaMax's Avatar
Don't have any pics but go with black, it keeps everything smooth.
Old Jul 19, 2003 | 07:52 PM
SuperFishstick's Avatar
how long before u can drive again?
Old Jul 19, 2003 | 10:42 PM
R5a7B's Avatar
Hey- I plan on painting my calipers in time. How long does the paint last for you guys? Does it get dirty quickly? After about how many miles? I'm looking into either black or red for my black max. Benefits of either? Thanks.
-Rich
REDinLV
Aug 15, 2024 12:30 AM
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
BobTX10
Oct 7, 2015 08:43 AM
