What springs should I get?
I'm going with KYB AGX's all around, I live in Central NJ so potholes are somewhat of a problem I don't want it dropped crazy, but I don't want anymore than a 2 inch gap between the fender and wheel. I want the ride to be as stock as possible depending on how I setup up the struts. I mean I don't want a really stiff ride I don't want to feel every single bump on the road. A good friend of mine NYCEMAX just got AGX's, and H&R springs he said the ride is near stock, like you can't tell the difference, and it looks and handles a lot better. Should I go with Eibachs or H&R's, I mean I don't go out buying springs and struts everyday lol so I mean I want to get it done right the first time. Thanks!!!
Also should I get KYB Strut Boots/Mounts? And what about Sprint springs how much of a drop do they give. If I get HRS or Eibachs will my car look lower is an inch and a half enough of a drop for the Max. So much confusion .
Re: What springs should I get?
Get the strut boots. Motivational mounts help a lot too.
Hey Tom btw I just called your shop asking for you and your advice :-D. I'm going to get it installed from your shop, I just have to figure out what I'm going to get. Ok so H&R's it is, I mean I was going to go with either HRs or Eibachs, but everyone is saying Eibachs are stiff, so HRs it is. Now I was originally set on KYB AGX's all around but I mean you do suspension stuff and I'm sure you know it like the back of your hand so I'll take your advice but just going to research it a bit more. Any other members here that have Tokico Blues up front, and KYB AGX on the rears? Thanks for your input, also why are the AGX's so much stiffer than the Tokico's just curious? Thanks!
Originally posted by NISM0
Do the eibachs make the car look lower than the H&R's? I mean is the car noticebly lower with the eibach? I used to own a modded civic with eibach sportlines, so I would'nt mind the eibach's harsher ride.
thanks guys
thanks guys
i drove an H&R/GR2 setup last month and yesterday i drove an eibach/agx setup and the difference in ride quality was minimal.. i'd go eibachs just cause the drop is more even and looks better than the uneven H&R look. eibachs are not as stiff as people make them out to be.
Tokico up front , KYB AGX in rear
car rides great - enough said !!! KYB AGX - are great struts , but it takes a while to find right setting for H&R springs , plus low temperatures make them quite stiff(fronts) .
H&R are not uneven !!! proof here:http://www.cardomain.com/member_page...=348507&page=6
car sits even with stereo in trunk.
my KYB AGX are still in the 4th Gen for sale forum and nobody wants them .....
Nick.
Nick.
MaxLvr21
10-17-2015 12:11 PM
