Spark Plug Wires?
Old Aug 2, 2003 | 07:52 PM
MaximusMax's Avatar
Spark Plug Wires?
I'm beginning to think that my spark plug wires are shot (along with using $h!tty bosch plugs), cause my idle is pretty strange. I'll be sitting at a red light at about 650rpm...then it will rev up to about 850, then back down, over and over. I talked to one of my buddies, and he recommended that I change my plugs to NGK (which are on order), and my wires as well. The car has 115k miles on it, and I doubt those wires have EVER been changed. I'm having a hard time finding the OEM wires. Can anyone show me where I need to go, or if there are better aftermarket wires available? Thanks
Old Aug 2, 2003 | 08:03 PM
mclarke's Avatar
uhm, we dont have spark plug wires , do we? i thought we had individual coil packs
Old Aug 2, 2003 | 08:58 PM
MaximusMax's Avatar
MMMMMMkay, then let me rephrase that....where's a good place to get coil packs
Old Aug 2, 2003 | 09:06 PM
infinitiman96's Avatar
a junkyard or the 4th gen for sale forums, they are way over priced at the dealer
Old Aug 2, 2003 | 09:10 PM
Ramius83
More than likely it is the spark plugs, not the coil packs. Only on rare occassions do the coil-packs go bad.
I would first change the plugs, and see how that works. If not, then clean out your throttle body and replace/clean the air filter.
Old Aug 2, 2003 | 09:26 PM
Sprint's Avatar
check your ECU ... if your coil packs are bad.. it will give misfire in X cylinder code
Old Aug 2, 2003 | 09:36 PM
MaximusMax's Avatar
Awesome...thanks for the advice.....Man I'm glad tomorrow's Sunday!
Old Aug 2, 2003 | 09:49 PM
Sprint's Avatar
oh btw.. if you get misfire in cylinder 2 .. switch the coil packs around.. then check the code again.. if the code still says cylinder 2 .. then the spark plug in cylinder 2 is bad.. not the coil pack.. if the code changes cylinder number.. then its your coil pack thats bad.. not your plug
Old Aug 2, 2003 | 10:29 PM
maxspeed96CT's Avatar
The original VQ...
I got a similar problem exept it gets worse on take off, do you guys think it might be the spark plugs.
Old Aug 3, 2003 | 07:35 AM
Jatan's Avatar
What kind of plugs you got in there?
The dealer I got my car from had AutoLite plugs in mine and that's why my car was a little sluggish, but now I put in copper NGK plugs and it's powerful again Almost beat a Mustang the other day
Old Aug 3, 2003 | 07:59 AM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
get some 9.5 MM spark plugs wires.....
Old Aug 3, 2003 | 09:21 AM
tom_98se's Avatar
Excellent advice. Getting the ECU code is one thing, but acting on it correctly is something different. Unnecessarily replacing an expensive part sucks (er, since I've done it.)
TOM
Old Aug 3, 2003 | 09:34 AM
The original VQ...
I have some cheap bosh plugs i got for like 2 bucks a peice, i just yesterday ordered some iriduim plugs from ebay so ill let you guys know if it helps when i put them in.
Need help
23
Oct 2, 2015 08:56 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
