Running a little rich after Y-pipe install
Old Aug 5, 2003 | 03:43 AM
PLUMMAXSE's Avatar
My 99 SE-L is running a little rich after installation of a budget y-pipe. Rich enough that it set off the O2 sensor with 07-07,05-10 codes. I read that as sluggish response from an overly rich cat sensor. I put some Techron gas treatment and ran a half of tank thru the car at a good clip. No more CEL. I'm thinking of going to a Frankencar intake and wondering will that help with leaning out the mixture? I drive short trips and the car doesn't warm up fully sometimes.
Old Aug 5, 2003 | 06:14 AM
njmaxseltd's Avatar
I assume your Cali Spec????
How is that pipe on your car? Can you feel more pull? How much did the exhaust note change?
Old Aug 5, 2003 | 06:32 AM
PLUMMAXSE's Avatar
Car is Fed model. Exhaust pull is much deeper and the car pulls just fine especially in the 3 6k range. No problems there!!
Old Aug 5, 2003 | 07:21 AM
Stephen Max's Avatar
Re: Running a little rich after Y-pipe install
A rich mixture can be caused by an exhaust leak near the O2 sensors (at the header/y-pipe joint). Air pulled in at the leak will register as a lean condition by the O2 sensors and the ecu will compensate by richening the afr. You might want to be sure that your y-pipe is good and tight against the header.
MAXEJA's Avatar
i also think you need to give the ecu time to adapt the change of having a ypipe on. im fed spec and have not gotten codes but just alot of fun and a great growl.
Old Aug 5, 2003 | 01:25 PM
PLUMMAXSE's Avatar
Re: Re: Running a little rich after Y-pipe install
Steve,
Do you know what the torque value of those bolts should be set? We are speaking of the 6 nuts that hold the y-pipe to the header.
Old Aug 5, 2003 | 01:26 PM
Re: Re: Re: Running a little rich after Y-pipe install
Steve,
No, sorry, not offhand. If I remember, I'll look in the fsm tonight.
Old Aug 6, 2003 | 10:43 AM
seegarman's Avatar
Did anyone replace all of the O2 sensors while installing the y-pipe? Since my car is at 130k miles, it may be close to replacement time anyway.
Old Aug 7, 2003 | 07:49 PM
PLUMMAXSE's Avatar
Steve,
You hit the nail on the head!! My rear header/y-pipe was too loose. I must have had a air leak which caused the riching of the mixture. I snugged all 6 bolts up to 40ftlbs. I'm not sure of the proper torque values. But thanks to all who helped. This list is GREAT
Old Aug 8, 2003 | 05:46 AM
Steve,
Yup. I know about this because it happened to me. Btw, the FSM said to torque to a range of 32-38 ft-lbs. Sorry I didn't get back to you about this earlier. 40 ft-lbs is fine, though.
Old Aug 9, 2003 | 01:35 PM
PLUMMAXSE's Avatar
Re: Re: Re: Re: Running a little rich after Y-pipe install
How long did it take before your CEL light stayed off? Mine is coming on every couple of days and I just reset it. Codes 0707 and 0510. Thinking I might have to replaced rear O2. Might try running a couple of tanks of Chevron(93) through her and see if that helps. Hell, a rear sensor from Courtesy Nissan is $70. Thats about the same money.
Old Aug 11, 2003 | 05:38 AM
Re: Re: Re: Re: Re: Running a little rich after Y-pipe install
According to the field service manual, code 0707 can also be triggered by an air leak. Check the tightness of your y-pipe to cat joint before you go out and buy a new o2 sensor. Buying a new exhaust gasket from the dealer fixed an air leak I had at that joint.
JRod28
Dec 29, 2023 09:56 PM
VQ'ed
69
Aug 27, 2020 12:29 PM
stromm
Aug 27, 2015 04:13 PM
Dasmith
Aug 25, 2015 10:15 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
