Knock Sensor reading
Old Aug 12, 2003 | 08:28 AM
JerzMax's Avatar
I took out my knock sensor and measured it with a ohmmeter. Connected both leads to each terminal and I got .555 reading. Connected one lead to the 2nd terminal and the other to ground and got no reading at all. Is my ks bad? I never got any codes for this but there is performance loss. Any suggestions?
Thanks...
Old Aug 12, 2003 | 08:37 AM
KINGMAX's Avatar
edit: you are supposed to test the resistance with an ohm meter.
Old Aug 12, 2003 | 08:44 AM
KINGMAX's Avatar
using the ohm meter if there is no reading there is an open circuit(no continuity between the terminals) you're KS is bad.
Old Aug 12, 2003 | 08:48 AM
JerzMax's Avatar
Thanks for correcting me. I didn't get any reading, but shouldn't have I gotten a code for it if it's bad? I manually checked for codes and nothing, it's been several months now...
Old Aug 12, 2003 | 09:03 AM
KINGMAX's Avatar
The KS wiil not cause a SES light and I think if it is not completely bad it will not throw a code. Somebody correct me if I'm wrong.
Old Aug 12, 2003 | 01:15 PM
JerzMax's Avatar
Is this true? Should I replace it then?
Old Aug 12, 2003 | 01:22 PM
BSwithTF's Avatar
The 0304 code while not make the CEL come on but it will be in there if you check the codes (if your knock sensor is bad).
Old Aug 12, 2003 | 01:24 PM
UncleMax98's Avatar
If you don't have code 0304, your knock sensor is ok. To check it you can use an ohm meter. One lead to ground, the other lead to one of the pins on the KS cable. One pin should gives about 550K ohm, the other pin should give infinite reading (no continuity). To have an idea of how bad the car performance is with a bad sensor, you can simply unplug the KS and take a test drive. The ECU should give 0304 code, and the car would be pretty sluggish. Don't forget to clear ECU code after you reattach the KS.
Old Aug 12, 2003 | 02:07 PM
JerzMax's Avatar
Thanks, I'll try that. How do I do the KS bypass?
bbsitum
Sep 6, 2019 07:31 PM
-ReLLiK-
Apr 29, 2016 06:25 PM
sdotcarter
Sep 2, 2015 09:53 PM
