Strange noise from top of engine
I have got a huge problem right now! My car is making a weird clicking noise, and for you musicians, it's in triplets (click-click-click). I start the car, it idles at 200 for a bit, then dies. I've pinpointed where the sound is coming from. If you are at the front of the car and looking down at the engine, it's coming from the top right, by the top right spark plug (intake side). If the car is on, but not started, it makes the clicking noise in that area. It's either the sparkplug, or that valve right next to that plug (has like 2 hoses coming off of it). Anyone ever have this problem? Need advice ASAP...Chicago Air and Water show is tomorrow and I needs to fix this. Thanks!!
Originally posted by CullenJ76
have you tried reseting your ecu? it's worth a shot. my guess would be the iacv too.
Locate the IAC when you hear the ticking. Put your hand on it (assuming that it isn't too hot since it doesn't run more than a few seconds) and verify that you feel something happening that corresponds to the ticking.
Also, it may be a good idea to disconnect and reconnect the harnesses that are located in that vicinity.
I unplugged the larger of the 4 plugs connected to the IACV and the clicking stopped, so it was that valve. Thanks guys! Now, question 2....that thing is on there like a beeyotch, so how the he!! do I take it off....any trick cause I was tryin for about 20 minutes with no progress. Thanks
If you can't get one, let me know and I'll try to cough up the directions later.
Check out this link:
http://forums.maxima.org/showthread....5&pagenumber=5
It will tell you how to get the IAC off. I would also suggest cleaning it if you are going to take it off.
Hope this helps.
Good luck,
D
This car is just a multitude of problems. Ok, I cleaned out the IAC valve and reinstalled it. The car actually started, idled at about 1200, then dropped to abou 850. I put the car in drive, then it died. So I've figured that either my car is getting too much/too little fuel, or too little/too much air. Any help guys?
derekinthez
Nov 13, 2022 04:00 PM
fastcarny
Oct 6, 2015 10:42 AM
