JWT/ECU a fake? Think mine is
Old Aug 15, 2003 | 03:14 PM
96shogunmax's Avatar
Well I have been seeing that the tach reads 5400 when the LED indicates the harlan is going off. So I did this...
When I set the harlan to 1k ... the light lit up at 1100
2k was alittle more
and so on
5k was at 5400
and my tach reads 7400 when the fuel cutoff takes effect.
So I set the harlan to 7k and it never opened up at all. I think I am going to set it to like 6900 just to see what that does. Anybody with a VI and JWT/ECU wanna try theirs like this? I dont know what to think right now.
Old Aug 15, 2003 | 03:19 PM
CullenJ76's Avatar
i don't know 'bout the question,but i like your car
Old Aug 15, 2003 | 03:23 PM
Just set it for 6800 and it went off(LED lit up) and my tach read like 7200ish
Now I will try the 6900 setting.
Old Aug 15, 2003 | 03:32 PM
The 6900 setting didnt go off. So it looks like my JWT/ECU is set at 6800 rev-limiter.
Old Aug 15, 2003 | 03:36 PM
Nismo's Avatar
its always going to be off. my harlan is set at 5,2k and it sets off a couple hundred rpm higher.
Old Aug 15, 2003 | 03:52 PM
My rev-limiter is 6800 b/c it wont open at 6900 when i set the harlan to that setting. My tach is 400 off. I can hit 7400 when the fuel cutoff takes effect.
Old Aug 15, 2003 | 03:53 PM
But if the tach if off that will cause the engine not to read what it is reving up to?
Old Aug 15, 2003 | 04:25 PM
Requin6's Avatar
when i dynoed the chart stopped at like 6900 indicating the fuel cut off if that is any help to you.
--Paul
Old Aug 15, 2003 | 06:30 PM
Mishmosh's Avatar
If you are trying to guess that it's a fake, don't! Nobody else [except JWT] has been able to touch the rpm limiter. Whether it is truly 7k rpm is another question. In any case, tach is definitely off... especially in 1st gear.
Old Aug 15, 2003 | 07:05 PM
plurco's Avatar
I would seriously blame the harlen before the ECU.
Old Aug 15, 2003 | 07:45 PM
Ceasars Chariot's Avatar
Old Maxima Legend
still working on getting my ecu, had a terrible time got wrong ecu and had to send it back and fight for my money, but i would hate to think im going through all this to end up with some fake ecu .. im just going to demand 7200 rev limit, and then take it to the track and expect a .1 or .2 to come off my 1/4 mile times.
if it does not, then i will cry out FAKE as well ... but for now im keeping the faith .. i sure hope your ecu is not a fake because that would suck ! good luck !
Old Aug 15, 2003 | 08:34 PM
Well I think the harlan might have a slight issue of this, but I was thinking about it and if my tach hits 7400 when it shuts down and then in the harlan is set at 5k and it shows 5400, that shows that its off by 400 rpm. The harlan wont work on 6900 or 7000 though. So I dont think its really the ecu if my tach is off by 400rpms. But the idle seems to be right, it slowly gets off track little by little all the way up to 7400.
Set at 5k ----> shows 5400
Set at 7k redline ----> shows 7400
Old Aug 15, 2003 | 08:35 PM
Dave B's Avatar
Not DAVEB the parts guy
--Paul
I've noted that dyno, on back to back runs, my stock ECUs rev limiter could vary between 6400-6500rpms.
ShogunMax-
There's nothing wrong with your ECU. The Harlan is just a little slow to react (100-200rpms slow). My rev-limiter kicks on at an indicated 7200rpms in 1st gear and 7100rpms in 2nd. I've never revved it to fuel cut in 3rd.
Dave
Old Aug 15, 2003 | 08:38 PM
Thats what kind of got me is that I dont really notice this low end loss that is suppose to be here with the MEVI. But tach off by 400 is wild.
Old Aug 15, 2003 | 08:56 PM
Dave B's Avatar
The loss really isn't in the lowend, it's from 3000-5000rpms which is more the midrange. The loss itself isn't terribly noticeable, but test it on the dyno and you'll see the lack of power. If you already had the ECU, then there isn't loss because the ECU restores all the midrange punch to where it was with the stock manifold.
Dave
Old Aug 15, 2003 | 09:00 PM
Yeh it was already in. And that is what I meant to say. (midrange)
So what do you guys think. When the fuel cutoff is like 6800 or 6900ish and it revs all the way, then the coil doesnt send a signal out?
Old Aug 15, 2003 | 10:55 PM
Iilac's Avatar
Spelled with a I not a L for Iilac. Prounced Ii-eee-ack.
On my ecu, in first gear, my fuel cut off is at 7k rpm. The later gears, the tach is off by 200 to 300 rpm.
Old Aug 16, 2003 | 10:12 AM
Nealoc187's Avatar
SLOW
My limiter is 7200 and on my recent dyno plot my car revved out to exactly 7200 when it hit the rev limiter, RPM signal taken off coil.
Old Aug 16, 2003 | 11:26 AM
But what does your tach say when it hits the rev limiter?
And can you set the harlan to 7k and it go off?
Old Aug 16, 2003 | 12:39 PM
speedemn's Avatar
On my stock ECU, on the dyno, I rev my tach to 6600RPM but the dyno drops flat at 6400RPM... I guess that means my tach is off by 200RPM.
Old Aug 16, 2003 | 12:50 PM
Anybody with the harlan wanna try this?
Old Aug 16, 2003 | 12:52 PM
Nealoc187's Avatar
SLOW
Mine's really close to dead on. Its between 7200 and 7300 when I hit the rev limiter on my tach.
Old Aug 16, 2003 | 12:54 PM
What could cause the tach to be off by 400 rpms.
Heat0212
Oct 24, 2020 12:36 AM
Apr 16, 2020 05:15 AM
gigabyte
Jan 6, 2017 06:05 PM
09maxshawn11
Sep 30, 2015 10:28 AM
Wareagle92
Sep 3, 2015 07:18 PM
