Overheating !
Old Aug 17, 2003 | 07:46 AM
Maximum96's Avatar
Overheating !
After about 30 - 1hr of driving my 96 max is hot as hell under the hood. when i drive, if i stick my hand out the window then the fans on the rad is blowing, i can feel the heat...any advice, should i change the coolant again, it has been a while...
Old Aug 17, 2003 | 08:11 AM
pocketrocket's Avatar
Ummm ... and your temp gauge says what?
When your exhaust temps are upwards of 400F, things can get a bit hot under there.
Old Aug 17, 2003 | 08:38 AM
Kevlo911's Avatar
Kevlo for President
how long has it been since u replaced your coolant? yes, what does hte temp guage show
Old Aug 17, 2003 | 09:06 AM
Maximum96's Avatar
temp gauge gets up to the half point mark, where it should be, i think it has been a while, i really dont remember, a while ago though, that i changed coolant. it gets really hot under there and u all know thats bad 4 performance. i checked coolant and i have little oil deposits, maybe a good rad flush would do the job?
Old Aug 17, 2003 | 09:11 AM
Kevlo911's Avatar
Kevlo for President
oil desposits in hte coolant is not good, do u have coolant in ur oil too?
Old Aug 17, 2003 | 09:29 AM
Maximum96's Avatar
no coolant in oil...at least that i do not know of, i change my oil myself and no coolant in the oil
Old Aug 17, 2003 | 09:34 AM
Time for an oil analysis.
Old Aug 17, 2003 | 02:24 PM
njmaxseltd's Avatar
It's prefectly normal to feel the intense heat of your cars engine coming from the radiator. It means your cooling system is dissapating heat, like it should be.
Temp gauge in the middle is normal engine temperature. Your car is not overheating, from your post, it sounds like your cooling system is working very well.
Old Aug 18, 2003 | 03:42 PM
supercobraz's Avatar
Re: Overheating !
I thought I had a problem earlier in the year because my fans were kicking on high. After paying attention to some other Infinities and Nissans, I'm confident it's normal. Still, when possible, I lift my hood when I get home oh a hot summer day....Can't hurt...not unless someone steals your battery..
Old Aug 18, 2003 | 03:47 PM
fearthegecko's Avatar
Most Perverted Member of the SE-L Club
Re: Overheating !
don't bother with changing your coolant, your problem is simple: Your car is working too hard in the summer heat. Feed it some gatorade (preferebly orange) and everything will work out fine. Also, it wouldn't hurt to take it out for ice cream every once in a while.
Ahh, i'm so lonely.
Old Aug 18, 2003 | 03:53 PM
99Maxima5sp's Avatar
Re: Re: Overheating !
Ahh, i'm so lonely.
ahh yes, also, dont forget to take it for a stroll in the park...
Eric
Miket2006
Mar 1, 2021 03:55 AM
RWCreative
Sep 21, 2015 11:01 AM
97_GXE
20
Sep 17, 2015 08:12 PM
97_GXE
Sep 15, 2015 06:47 AM
