ecu code 10-03 (park/neutral error)after 5 speed conversion please help!
Old Aug 22, 2003 | 06:37 PM
nanomax96's Avatar
It's been about two months since I had this problem and it's been about two months since a completed the conversion. So I'm almost sure it's related to it. I'm thinking I either have to plug or unplug something but I don't know what. Can anyone help me please? Thanks in advance
Old Aug 23, 2003 | 05:41 AM
Kevlo911's Avatar
Kevlo for President
this might help http://forums.maxima.org/showthread....highlight=1003
Old Aug 23, 2003 | 01:51 PM
nanomax96's Avatar
I looked at that tread but I't doesn't say where this switch or plug is. Thanks for your help anyways though.
Old Aug 23, 2003 | 01:55 PM
Kevlo911's Avatar
Kevlo for President
buy a haynes manual from autozone for 15$, look on page 7b-7, i don't have digital camera or flatbed scanner, if i did i would email u the page
Old Aug 23, 2003 | 02:05 PM
nanomax96's Avatar
I went to kragen, autozone, and pepboys and none had it in stock the closest I found was 90's model 300z if you can just tell me in what vasinity this part is located I'm pretty sure I can find it. thanks for all your help.
Old Aug 23, 2003 | 02:16 PM
Kevlo911's Avatar
Kevlo for President
actualy, it says that this part is for the auto, it says its so you can't turn hte car in anyother gears besides neutral and park.
the picture is a zoomed up one so i can't tell you where it is. but i think it is gear where hte auto shift cable was. there are 2 connectors, one harness can hold 8 wires but has 7 going to it and the other has 2 wires
if you can't find, i would not worry about it since u have a stick now and since that code is for a auto
Old Aug 23, 2003 | 02:53 PM
Nismo's Avatar
I got the answer here- on your harness right above the tranny, look for a large plug that has 2 wires in it, (I think theres a green gasket inside of it) anywyas just get a wire and connect the 2 wires together and reset your ecu, thats it.
Old Aug 24, 2003 | 01:46 PM
nanomax96's Avatar
I will try that thanks for your help!
Old Aug 24, 2003 | 08:04 PM
nanomax96's Avatar
I tried connecting those two wires and now my cruise control won't work. Does anybody know any other way to get around it. thanks in advance!
Old Aug 24, 2003 | 09:08 PM
96shogunmax's Avatar
you got to get the auto harness and hack it into the 5spd one
Old Aug 24, 2003 | 10:25 PM
Nismo's Avatar
well I heard your supposed to connect those wires to the bottom sensor of the clutch. I didnt so thats why I can start the car without pressing the clutch since I did what I told you to do which is bypassing the switch making the car think the clutch is being pressed on all the time. good thing is no more code, bad thing is no cruise control which I dont mind, I never used it.
Old Aug 25, 2003 | 08:22 AM
nanomax96's Avatar
I hooked up the reverse/backup lights but I don't know what the other 10 wires go to. Does anybody know the wiring diagrams for the five speed and auto tranny, I really need to get this done I have to pass smog within tree weeks. thanks for trying to help me out guys!
Old Aug 25, 2003 | 10:55 AM
nanomax96's Avatar
Does anybody have any other Ideas
Old Aug 25, 2003 | 04:24 PM
nanomax96's Avatar
Anybody
mvm062
Nov 30, 2020 09:00 AM
gustavison
Oct 4, 2015 06:50 PM
QueensMAX
Sep 15, 2015 04:14 AM
lux97Max
Sep 11, 2015 01:12 PM
Hdnseek
Sep 9, 2015 05:55 AM
