New idea, for low and high end power
Old Sep 25, 2003 | 08:04 AM
  #81
dwapenyi's Avatar
The CAI is more restrictive than a POP simply because of the long piping. Ultimate peak flow in a POP may be a bit better, but a CAI is better than a POP in that the air temp is more consistent in temperature, it doesn't change so much as a POP does. Also, the CAI flow is very straight going through the MAF because of the long tubing. The POP needs a velocity stack whereas the CAI does not.
DW
Old Sep 25, 2003 | 08:50 AM
  #82
nismos14's Avatar
§è~® f®ÈÄk
Originally Posted by venompwr2
the CAI "chokes off" at top end because of not enough air circulating in the wheel well? Right? Well why not use a cai, and then have a tube from the foglight opening going right up to the filter, thus possibly even making a ram air type deal that will always have plenty of cool air, and rain cant very well shoot vertically up a tube (unless driving through very deep puddles/flooded roads, which isnt smart anyways)
the rain can't shoot up vertically BUT it can be sucked up, which it seems like you forget is what the engine does, so the water can get up there regardless
Old Sep 25, 2003 | 02:38 PM
  #83
venompwr2's Avatar
lol I'm dumb sometimes, looked right over that...
Old Sep 25, 2003 | 02:48 PM
  #84
nismology's Avatar
From what I've read, the CAI just exhaggerates the lacking top-end of the USIM. In many other car's with great top end, such as VTEC engines and VVTL-i, CAI perform better than SRI. I personally wouldn't get a CAI unless I had MEVI.
Old Sep 25, 2003 | 06:58 PM
  #85
venompwr2's Avatar
ah this thread is beat...but why do I keep posting in it.... Lets all just go with our own personal prefernce of intakes!
Old Sep 25, 2003 | 07:04 PM
  #86
SXN's Avatar
SXN
dont drag us down any more, lol... weve essentially beaten this issue to death. air takes the path of least resistance blah blah blah... we're done
Old Sep 25, 2003 | 10:34 PM
  #87
nismos14's Avatar
§è~® f®ÈÄk
the difference in power on intakes is like 1 - 4 hp its not even worth all this debate, pick whichever one gives u the most driveability and u'll be happy
Old Sep 26, 2003 | 04:18 PM
  #88
SXN's Avatar
SXN
since a shorter intake is better at high speeds, and a CAI is better at low speeds... what gives better results on the drag strip? (without ram air or anything tricky)
Old Sep 26, 2003 | 10:57 PM
  #89
nismos14's Avatar
§è~® f®ÈÄk
short ram because ur in the upper rpm range alot more at the drag strip than down low
Old Sep 26, 2003 | 11:14 PM
  #90
SXN's Avatar
SXN
i thought that cold airs were good off the line because it was instant cold air on tap. and a short ram was bad at first because hot air in the engine, and better the faster you go because the air flow gives it cold air. so is it car speed or RPM?
vybz05
Dec 10, 2015 07:38 PM
Finkle
Sep 27, 2015 09:53 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Hawkeye61
Aug 12, 2015 06:45 PM
kjm900r
Aug 5, 2015 07:14 AM
