Airbag light flashing- battery died later
Old Sep 16, 2003 | 06:00 PM
san1tar1um's Avatar
3 days ago, I went for a drive in the middle of the day and noticed that my airbag light was flashing, it was flashing steadily, no codes. That night, my battery died. I replaced the battery, but my airbag light is still flashing.
I did some searching on here, and tried to reset the airbag system using the door-light button method. First, I got a code, two long flashes, followed by a short flash. Then I tried doing the method twice in a row (read that it puts it into user mode?) and now it is back to flashing steadily, no codes.
Does anybody know what is going on with my car? First the light went on, and then the battery died. I'm guessing that the light went on in the first place because my battery was about to die, but why is the light still on? What does that code mean, and is there anything I should have done after I replaced the battery (ie. reset the ECU?) Thanks for any help that is given.
Old Sep 16, 2003 | 06:14 PM
ManualMaxima's Avatar
5th Gen till she dies!
Mine did that when my alternator ****ed up. It did the same thing in my girls sentra.
Old Sep 16, 2003 | 06:16 PM
san1tar1um's Avatar
and...? What happened?
Old Sep 16, 2003 | 06:17 PM
The light would come on the my battery would die, ten my car would cut off. so i got it to the shop finally and i needed a new alternator, and starter.
Old Sep 16, 2003 | 06:21 PM
SXN's Avatar
SXN
usually the current issue isnt the battery, and if it is...easy fix. can be an alternator issue, bad ground, or a corroded wire. have someone with solid car knowledge looking at it (no offense to you, i couldnt fix this myself either) and if still no ideas, take it into the shop.
Old Sep 16, 2003 | 06:32 PM
san1tar1um's Avatar
So you guys think that it isn't a simple solution like resetting ECU or something like that...
Cause thats what I'm afraid of, I just had the alternator replaced about a month ago... Thanks for the help
Old Sep 16, 2003 | 06:45 PM
SXN's Avatar
SXN
why did you have it replaced the first time?
Old Sep 17, 2003 | 06:26 AM
san1tar1um's Avatar
The car died on me completely, there was supposedly a bad diode on the alternator or something.
Old Sep 17, 2003 | 05:53 PM
SXN's Avatar
SXN
it sounds like something is wrong again...but since you got a relatively new alternator i doubt its that. the voltage is draining the battery because the system isnt making enough amperage to keep itself going. since the alternator is new, and since your draining the battery, there has to be a wiring issue or short somewhere on the car...no other explanation (unless you broke another in a month?!)
Old Sep 18, 2003 | 04:56 PM
san1tar1um's Avatar
Does anybody know how I can figure out what the airbag codes mean? Thanks.
sctludwig
Sep 1, 2022 01:32 PM
The Frye
Sep 2, 2021 11:03 AM
mvm062
Nov 30, 2020 09:00 AM
markevans999
Sep 10, 2015 04:29 PM
Maxima30
Sep 7, 2015 06:13 PM
