Clutch slipping???
Old Sep 16, 2003 | 06:52 PM
maxedup97's Avatar
Clutch slipping???
I have a 5 spd, when I'm in first and put it to the floor it takes off. When I'm in 2nd, 3rd, 4th, and 5th and put it to the floor the RPM's go up about 300-800 rpm and then come back down. My question, do I need to buy a new clutch, like and ACT clutch, or is there an adjustment on the clutch/housing that I can do??? It's driving me crazy, it just started to do it over the weekend.
Old Sep 16, 2003 | 08:34 PM
nismos14's Avatar
§è~® f®ÈÄk
seems like u have a slipping clutch, if u take it up to about 40 mph in 5th gear and punch it, what happens? try it out
Old Sep 16, 2003 | 08:40 PM
pjalst
I think mine is slipping too
Old Sep 17, 2003 | 08:47 AM
SkyMax4's Avatar
i am having the same problem. i had a act clutch for about 2months till i got a leak in my tranny. i think its ruined. i just posted and ask about that. as far as your clutch for sure you need a new one. i suggest act because i picks up right off the floor.. its a great feeling.
Old Sep 17, 2003 | 08:54 AM
maxNYC's Avatar
Could be the clutch fluid you are using. Have you changed it to something other than stock?
Old Sep 17, 2003 | 09:30 AM
99Maxima5sp's Avatar
Hmm, thats typically a slipping clutch. However, mine was slipping badly, and whenever i punched it, i never had that problem, only shifting would it slip.
Now, if your not going to be boosted, or spraying, theres really no need for a ACT or anything strong like an Exedy. If your going with just bolt-ons just get yourself an OEM clutch. MAKE sure its an OEM, NOT OEM equivilant (sp?)
Eric
Old Sep 17, 2003 | 03:00 PM
maxedup97's Avatar
it doesn't matter what speed I'm going, it still slips. I've used the same fluid from nissan, I can't remember what it is though. So you think an ACT clutch "Stage 1" would be a good bet? I found it at http://maxmods.dyndns.org/index.php?MaximaClutches I am only going to have bolt-ons. Thanks for your help
Old Sep 17, 2003 | 05:40 PM
I guess you definately just skipped over my last post ..
Running an ACT clutch when you are only planning bolt-ons is overkill, stick with an OEM clutch. You only need a strong clutch (i.e. Exedy, ACT) if your boosted, or spraying....
Eric
Old Sep 18, 2003 | 03:19 PM
maxedup97's Avatar
Sorry 'bout that Eric, so how much is an oem clutch??
Old Sep 18, 2003 | 05:10 PM
i believe you can snag one at the stealership in the 200's...I cant actually quote you a price though since i dont know, try checking with courtesy nissan....
Eric
Old Sep 18, 2003 | 07:54 PM
rguida's Avatar
I just bought an OEM for 290 from dealer
Old Sep 18, 2003 | 08:16 PM
pjalst
Que
How long from the time you first notice some slipping until it fully goes?
Old Sep 18, 2003 | 09:31 PM
If you baby it, im sure you can go awhile...
Mine went from being able to chirp second, to not being able to chirp, to slipping in a coupla thousand miles...However, i tried to spray a 50-shot and it baked the clutch...So mine was a pretty rapid decline...
Eric
Old Sep 19, 2003 | 09:41 AM
pjalst
I just had a Y pipe installed and I haven't chirped yet, at least I don't think I have.
Old Sep 19, 2003 | 09:45 AM
ManualMaxima's Avatar
5th Gen till she dies!
i had that problem, First would be perferct but 2nd and up was apain in the ***. I would prss the gas and my revs would shoot up then come back down. Yes i know mine was a slipping clutch, and just had it replaced.
Old Oct 18, 2003 | 08:08 AM
sadice's Avatar
which one did u get and how much???
Old Oct 18, 2003 | 10:28 AM
my dad made me get a stock clutch, i had a act. the place down the street did it for $599 installed. better than the dealership.
Old Oct 18, 2003 | 11:17 AM
pjalst
I'm so happy I'm all growed up
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
carlosvq30
Sep 26, 2015 09:44 AM
