Free Horsepower for mechanics.
whatup. OK some of you keep wanting to get more HP so ill tell you what i did the other day.
Replaced all small vacume hoses to EGR, EVAP, Selonids $3mod
Removed the intake Manifold (again) and Cleaned it w/ 2 cans of TB Cleaner. (only 2nd time ive done this on my 95) $5mod
Removed IVAC and thoroughly cleaned it with small cut toothbrush
(with TB cleaner) $.50
Removed TB and thoroughly cleaned it with small cut toothbrush
(Both Sides)(with TB cleaner) $.50
AFTER:
RPMS went up 1500 @idle, i knew theres been a small vacume leak
(BTW This also fixed my rough idle kinda after 6months of ecu codes, yeah i still get the code but it runs great)
Throttle Response is Instant.
Acceleration is Much Smoother.
Intake is Louder and Sounds Nicer.
Get ur craftsman sockets and go to town! Ull appreciate this more that a $money$ mod. Ur car appreciates it
AFTER:
AFTER:
AFTER:
nice--thanks
man i dont know where half this stuff is and read the faq's from what i rememeber theres no pics in the faq about where this stuff is... all i now obviously is the TB lol oh yeah and i now where the mani is and the evap canister blah!
Originally Posted by Max96GLE
I want to change it. Where did you order the parts? I"m not sure if the parts i'm getting will fit. Thanks for your help.
THE IVAC gasket, No i didnt replace the gasket there. i probably should of but everything is fine.
I keep my clean
I just went to my local autoparts store and lined up the hose's with my egr and other hoses under the TB.
I keep my clean
I keep my clean
Originally Posted by matty
These are good tips but I wouldnt wanna remove the manifold just to clean the runners...
-matt
-matt
but the uppermanifold was sooo sooo dirty it was ridiculious...
Alot and I think it is Pointless to take off to Clean
-matt
-matt
i must disagree when u say pointless.those carbon deposits that you scrape off on the opening of the manifold and the TB are constricting the freeflowing air.plus,it would be a good time to clean the EGR after you take off the intake manifold.you wouldnt believe how much carbon you can take off from that little hole.and yeah, IACV and TB shouldnt be that bad.
I would not take off my intake manifold if i didn't have to.. you must be bored out of your fcking mind to do some **** like that..
after installing my VI .. i wouldn't do that **** for maintenance
but if any of you are bored out of your fckign minds one day
http://www.vanillaice.com/webmasters/hype/mrc/mevi2.htm
Originally Posted by Dave B
Am I reading this right that your idle is 1500rpms now? That's not good. It should be around 600rpms with a warm engine and manual tranny. 800rpms if you're an auto.
Dave
Dave
Yep you F'ed up your idle.....time to adjust that next.
And OH ya......
Anyone know what size tubing is required for the Max?? My 95 tubing is cracking all over the place from what looks to be dry rot, and I'd like to replace it all but I have no idea what size tubing I need to get, and should I get it on a roll or buy it in sections?
I feel the same way..anyone that would take off there manifold off to clean it has alot of time on there hands..its Pointless
-matt
-matt
Its not pointless, or a waste of time, some of us (me included) just dont have/want to spend the time doing that.
-matt
-matt
So was my 2hrs and 6$ of effort worth better throttle response/ better gas mileage/ louder WOT well..........u decide
-matt
-matt
In the end, I just feel that the gains you get out of cleaning these parts are so minimal that it's basically not worth the time. But then again, like I said, it doesn't hurt so if you have the time and patience go ahead and do it!
I dont know why that's so funny, but it is!
-matt
-matt
Originally Posted by Shift_Power
Wow, bit of hating going on - everybody is so friendly to "bobjohnson" when he's just trying to help people out if they want to spend the time...Way to go people!!
mkaresh
03-12-2018 06:48 PM
06-06-2017 02:01 PM
