groan noise on braking
Old Sep 17, 2003 | 11:39 AM
SamMan23's Avatar
When I am braking, I hear a groaning noise as the wheels slow to a stop. This happened after I changed my brake pads(carbon metallic Performance Friction), resurfaced rotors(69k miles), and changed my driver side cv shaft. I'm suspecting that the cv halfshaft is making the noise. Does anybody else have any insight?
Maybe I'm better off with ceramic oem pads? Maybe cv halfshaft is bad. I don't know but it's annoying.
I'm pretty sure it's not my tires either because I had plenty of tread on them. The problem started after I changed out my cv axle and started using Performance Friction Carbon Metallic pads. I did both the same day. And yes I did get an alignment after all this.
Although my other drive axle cv boot went bad too 2 weeks later.
Old Sep 17, 2003 | 12:35 PM
slfalco's Avatar
I have that same noise from the left front when braking, also I hear a noise when turning right at slow speeds. The dealer replaced the wheel bearing, but it is still doing it, and they claim it is my tires... I think it must be the CV joint in the axle, but they did not agree, and since it was still within the 60K drivetrain warranty, they refused to do anything under the warranty...
Old Sep 17, 2003 | 12:49 PM
BadKarma99-4spd's Avatar
i have the same groan, has anyone tried getting one of those brake rebuild type kits?
also how much did they charge you to resurface your rotors, midas quoted me like 300 for that and something else, so i essentialy told them to go to hell.
thanks
Old Sep 17, 2003 | 03:15 PM
supercobraz's Avatar
Here in Austin, Midas resurfices rotors for $18 apiece. I also get that grinding groaning sound from my front brakes. My brakes are all messed up. I mean, I'm about to put on a 3rd set of front rotors because they keep warping. I'm taking it to the dealer soon because Midas or no one else can help me.
Old Sep 17, 2003 | 03:17 PM
LouieDumps84's Avatar
thanks
They should charge around 10 to 20 bucks a peice. Best bet .. i work in an auto parts store.. so i see this all the time... get new rotors. when you put on the rotors (or have them cut, if you cant afford new ones) make sure to torque your wheels to the 75 ft/lbs. (thats what nissan calls for on gen 4 maximas) If you torque them you might not even need to cut your rotors, it worked on my last car .
Old Sep 17, 2003 | 03:56 PM
SamMan23's Avatar
Actually, CV axle is not covered under drivetrain. I know it's real stupid that it's not covered cause your car couldn't go forward or backward without it. But it's considered to be part of steering and suspension by Nissan. I called Nissan Corporate about this and they said the part number is not covered.
I hope Tom (NJMaxseltd) chimes in on this thread because he knows lots about these types of issues.
Old Sep 17, 2003 | 07:49 PM
ive got brembo oem replacements and they are only about 5months old, i put them on and have had no problems since, but in the last month my pads have begun to squeek so i am going to purchase new ones(most likely oem unless someone wants to suggest something cheaper that wont squeek) and most people ive talked to recommend getting the rotors resurfaced when you go with new pads.
comments suggestions?
thanks
Old Sep 18, 2003 | 04:56 PM
97MaximaSE's Avatar
my metal masters groaned like a **** but i just switched back to stock nissan pads the other day and no more groan
Apr 16, 2020 05:15 AM
D Mason
Jun 21, 2016 04:43 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
