starting problem
Old Sep 21, 2003 | 08:17 AM
billy_corgan's Avatar
Starting problem, chipped key problem???
This is a completely intermittant problem. Most of the time the car will just turn over and start normally. But every few days I turn the key and the engine just turns. Then it will start and die. Even if I give it gas it will start and then die. The more I keep trying to start it, the less it even starts. The only way to move my car when it does this is to put it in 1st and take off from the start. My MAF is good. All sensors are working correctly. Could this be a problem with the wrong chipped key?
Thanks.
Old Sep 21, 2003 | 09:35 AM
Kevlo911's Avatar
Kevlo for President
get ur batter tested at autozone for free and have ur alternator tested too. check all ur vacume lines and make sure they are connected properly. the vacume lines are connected the resonator inbetween the maf and throttle body
Old Sep 21, 2003 | 09:39 AM
Jatan's Avatar
Clean your battery connections and have it tested like kevlo said.
Old Sep 21, 2003 | 09:42 AM
my vacuum lines are connected properly, but one of them is just slightly twisted. It is not pinched shut. Still open almost all the way. Would this cause any problem?
Old Sep 21, 2003 | 09:48 AM
Kevlo911's Avatar
Kevlo for President
well it should not be the problem as long as it is getting enough air. try to unpinch and see what happens
Old Sep 21, 2003 | 02:43 PM
baltimax's Avatar
Definitely check that twisted Vacuum line. A vacuum line broke and basically killed my old car because it was so hard to find. My car would still start up but it wouldn't go past 25mph.
Old Sep 23, 2003 | 03:52 PM
I brought the car to nissan dealership today, they couldnt find anything wrong with it. They saud the reason I might be having the starting problem was because of the key and the anti-theft NVIS system on 99's. Has anyone had a problem with this? I didnt think my key was chipped. What does a chipped key look like? Cause mine looks like avery other key.
Old Sep 23, 2003 | 05:24 PM
njmaxseltd's Avatar
Check both your crank position sensors. They tend to collect fine metalic dust on the pick-up which makes the signal weak. There are 2 sensors, one is POS and one is REF. POS is most likely the cause of your hard starts. It's loacted under the car on the transmission bell housing twards the front. Remove it and clean the tip. The other sensor looks at a timing ring on your lower pully. Clean the tip of that off as well. If that doesn't cure your hard starts, change your engine coolant temp sensor.
If you can get your car to start by jumping it in first gear, then your immobilizer is reading your chipped key correctly.
Old Sep 23, 2003 | 08:48 PM
and neither of these sensors would throw a code I take it? I will try both of these. Thanks, I was about to have nissan reprogram my keys
Old Nov 1, 2003 | 08:03 PM
maxNYC's Avatar
a bad engine coolant temperature sensor will cause the problems you are describing. i'm talking from experience.
Oddly enough, the ECU did not report a code for this problem either. after changing the IACV, knock sensor, cleaning the throttle body and triple checking the wiring harness connections, it all boiled down to this.
hope this helps!
Old Nov 2, 2003 | 05:48 AM
Jatan's Avatar
hope this helps!
About how much is that sensor?
Old Nov 2, 2003 | 06:05 AM
Kevlo911's Avatar
Kevlo for President
a coolent temp sensor is about 25$ from www.newnissanparts.com
Old Nov 2, 2003 | 06:28 AM
Jatan's Avatar
matts95max
Apr 23, 2025 10:44 AM
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
trungg86
Sep 4, 2015 04:58 AM
dcardello
Sep 3, 2015 11:44 PM
