New here- have a serious problem.
Old Sep 29, 2003 | 12:43 PM
Hagarr's Avatar
What a great site! I have already checked the FAQ and searched for this problem...I may have missed it though.
Thanks for any help.
Car: 97 Maxima automatic, 80k, well maintained w/ Mobil 1 synthetic 5w30. Car is in Houston.
The only consistency is this- after the car sits for 2 or more days upon start up I hear a very rough loud low pitch growl/ping grind for a few seconds and then it goes away. This has happened twice. Two weeks ago and two days after fresh oil change. This second time it made the loud pinging noise and ran rough for at least 15 secs before we turned it off.
what is up?
Old Sep 29, 2003 | 12:44 PM
maxNYC's Avatar
check your fluids first.
Old Sep 29, 2003 | 01:13 PM
Hagarr's Avatar
yup...all fluids checked and no leaks.
B
Old Sep 29, 2003 | 01:16 PM
delacruz_17's Avatar
could it be the timing chain tensioner?
Old Sep 29, 2003 | 01:22 PM
njmaxseltd's Avatar
What brand of oil filter are you using?
Old Sep 29, 2003 | 01:48 PM
Jatan's Avatar
Have you done your 60k tuneup? Are you using 91+ octane fuel?
Old Sep 29, 2003 | 02:23 PM
Hagarr's Avatar
Thanks for the replies.
WIX filter- don't use 91 octane...put in the cheap stuff.
Old Sep 29, 2003 | 03:00 PM
BOSS
there u have it...
Old Sep 29, 2003 | 03:06 PM
MrEous's Avatar
^ Jeff™
Anything less than 91 will freak your engine out and make your knock sensor work overtime catching knocks/pings.
Old Sep 29, 2003 | 04:15 PM
Hagarr's Avatar
I can understand the octane issue however why does it only do it on startup and once the car has been sitting for 2 or more days?
Old Sep 29, 2003 | 05:01 PM
BOSS
Your Max is letting you know that it can handle 91- octane for a while, but two days is just too damn long!
Old Sep 29, 2003 | 05:26 PM
Kevlo911's Avatar
Kevlo for President
try to change ur oil again with a nissan or better filter. maybe u got a faulty filter. let someone else turn on the car and try to pinpoint where the noise is comming from
Old Sep 29, 2003 | 06:06 PM
njmaxseltd's Avatar
Get rid of the WIX filter and go back to OEM. Also the 5W-30 is a bit thin for Texas. Go to a 10w-30 weight.
The check valve on the WIX filter may not be holding oil up in your oil passages and causing your cars engine to have a dry start. 5w-30 thin oil is probably not helping the issue either. The two combined are probably causing your problem.
Old Sep 29, 2003 | 07:08 PM
tattoo's Avatar
oil drains off valvetrain parts,takes some time to get up there when cold,hence the noise.i wouldn't worry.timing chain would make this noise at all times.
Old Oct 8, 2003 | 09:47 PM
manoli75's Avatar
Ocatne!!
Had same problem as you, but after every start---after putting low octane in my gas tank because gas station was out of high octane. Make sure you use high octane--engine will knock on start up if there is low octane in your car(will sound like the engine has very serious problem).
Old Oct 9, 2003 | 09:25 AM
Hagarr's Avatar
Thanks everyone.
B
Old Oct 9, 2003 | 09:38 AM
kenji's Avatar
And if they haven't made it clear, DO NOT EVER USE LESS THAN 91 OCTANE.
Just wanted to make this EXTRA CLEAR. Peace.
Old Oct 9, 2003 | 12:12 PM
Jatan's Avatar
This'll make it EXTRA CLEAR:
DO NOT EVER USE LESS THAN 91 OCTANE!!!
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
D Mason
Jun 21, 2016 04:43 AM
Noela
Sep 26, 2015 08:22 AM
