Hissing sound coming from rear
Old Oct 6, 2003 | 06:21 PM
rik3k's Avatar
I'm not entirely sure where it's coming from as I haven't gone under the car to check it out, but it seems to be coming from just in front of the rear wheels. What could be causing a hissing sound back there? I have a 95 SE (completely stock). Any ideas?
Old Oct 6, 2003 | 06:24 PM
philly96maxima's Avatar
...A SNAKE HIDING IN THE WHEEL WELL?
Old Oct 6, 2003 | 06:40 PM
Jatan's Avatar
It could be the tires or maybe the wheel bearings
Old Oct 6, 2003 | 08:09 PM
KWheelzSB's Avatar
If the car is running at idle and you're sticking your head under there, it could simply be the fuel pump.
Try this: With the car off, turn the ingnition switch to the "on" position without starting the engine. You should hear a hissing sound for a couple seconds, as the fuel pump primes - is this the sound you're hearing? It sounds the same, but continuous when the car is running.
If that's not it, you may have an exhaust leak - inspect the muffler and b-pipe for holes/cracks - if necessary, you may be able to patch it with an exhaust patch kit from your local auto parts store. If it's really bad, you may need to replace either the b-pipe or muffler.
Old Oct 6, 2003 | 08:27 PM
SXN's Avatar
SXN
could be a small air leak? i think u would notice that though
Huttig2009
Sep 25, 2015 03:31 PM
BobMax
Aug 15, 2015 12:35 PM
Mcnabb34
Aug 11, 2015 08:45 PM
follyburr
Aug 7, 2015 09:50 PM
Jcof88
Aug 3, 2015 10:43 PM
