well I found my problem:-(
Old Oct 9, 2003 | 07:00 PM
plurco's Avatar
I have posted several time about my car loosing oil. well I did a compression test the other day and found 126PSI in #6. This being said I just bought a new engine. 59K miles $450. I am using the oppertunity to change out my clutch disc while I am in there, as well as filling my motor mounts with poly. Anyone have any other suggestion of things to do with the engine out? Also can anyone think of a reason that the place I am getting the engine from would be charging me a $50 core charge when buying a used engine? this sounds like a crock of ****.
Old Oct 9, 2003 | 07:04 PM
Street Reeper's Avatar
Handsome
D@mn sorry to hear that. Did your car give any signs that the motor was pooped, stumbling hesitation, lack of acceleration etc.
Best of luck
Old Oct 9, 2003 | 07:05 PM
plurco's Avatar
Best of luck
it has a slight problem while driving on the highway, it will hesitate for just a sec every now and then but it is unrelated. I think it is the TPS. it still runs like a scalded dog.
Old Oct 9, 2003 | 07:06 PM
Handsome
PM SeximaGTR, I know he just bought a new motor and he is a real good guy to get advice from.
Old Oct 9, 2003 | 07:10 PM
Dave B's Avatar
Not DAVEB the parts guy
What was your compression in all the other cylinders?
Dave
Old Oct 9, 2003 | 08:23 PM
plurco's Avatar
145-150. why you know something I dont?
Old Oct 10, 2003 | 04:29 AM
njmaxseltd's Avatar
126 in one compaired to 145-150 in the others might not be a problem. You should have done a leak down test or repeat the compression test again at different operating temperatures and then compair all the data you collected.
Old Oct 10, 2003 | 08:39 AM
Scruit's Avatar
U wanna try me young boy?
140-150 is on the low side all round, it seems. Are you sure you did the test right?
- Use a screw-in tester, not a hold-in tester
- Ziptie the throttle plate wide open (or floor the gas pedal)
- Put a little bit of oil on the threads for a better seal
- Then drop a teaspoon of oil in the cylinder and repeat the test
Old Oct 10, 2003 | 08:46 AM
MrEous's Avatar
^ Jeff™
So they can have your engine possibly rebuilt so it 'works' enough to sell it to someone else. Just their way of turning a profit into more of a profit.
Old Oct 10, 2003 | 08:49 AM
Scruit's Avatar
Plus they can sell the heads, oil pan and other non-damaged parts, etc and then melt the block for scrap.
Old Oct 10, 2003 | 08:15 PM
plurco's Avatar
it's just the fact that they are charging my a "core" charge. wich by definition means i am buying a rebuit product which I am not. I am purchasing a surplus product.
Old Oct 10, 2003 | 10:41 PM
Dave B's Avatar
I think the compression, while a bit low, is okay. It's really not how high the numbers are, it's how consistent the numbers are across the board. I could have sworn that compression between all cylinders should be around 10-12%. Your cylinder #5 is about 13%.
I would have done all the tests above and even run on a dyno and done some more track testing. I fear you just purchased a replacement motor you really didn't need.
Dave
Old Oct 11, 2003 | 05:38 AM
plurco's Avatar
didi I mention that I am loosing a quart of oil every 3-4 days?
Old Oct 11, 2003 | 07:09 AM
CullenJ76's Avatar
where from?
Old Oct 11, 2003 | 07:10 AM
PoePoe2797's Avatar
Burning or dripping?
Old Oct 11, 2003 | 08:57 AM
plurco's Avatar
burning oil
Old Oct 11, 2003 | 09:17 AM
deezo's Avatar
burning oil
Do you see blue smoke when you startup in the morning and does the exhaust smell clean? Has the car ever been driven while overheated? Could be a gasket issue.
jmlee44
Oct 2, 2022 02:13 PM
D Mason
Jun 21, 2016 04:43 AM
MaxLvr21
Oct 17, 2015 12:11 PM
BobTX10
Oct 7, 2015 08:43 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
